2Addicts | BMW 2-Series forum Technical Topics Mechanical Maintenance and TSBs: Break-in | Oil & Fluids | Servicing | TSB "Replace Battery" at 22 miles on '18 M240i??
      12-05-2017, 10:46 PM   #1
stevenvillatoro
stevenvillatoro's Avatar
2018 BMW M240i  [0.00]
I took delivery of an new M240i a few days ago. Tonight, I went to put some backroad miles on it, just to get acquainted.
I was greeted with a "Replace Battery" warning on the dash cluster. The car had 22 miles on it. I thought I'd try charging the battery by driving it, as planned. Ended up adding 29 more miles, but the "Replace Battery" warning persisted.
I texted my salesman. He replied, "Yeah. Once the car gets to a certain battery level that message won't go away even though the battery is perfectly fine. Really frustrating. I will check with my manager tomorrow to see what needs to be done." WTF?
Any experiential forum feedback on this issue? Is there a DIY reset, maybe? I'm sure it'll all get worked out tomorrow, but nothing beats first-hand experience. Thanks, in advance!
—Steve
'19 MX-5 Miata GT-S soft top
Past BMWs: two '57 Isetta 300s, '70 1600, '72 Bavaria, '78 320i, '18 M240i
      12-06-2017, 03:44 PM   #2
stevenvillatoro
Battery replaced, as a mandated BMW precaution. Took all of 45 minutes, easy peasy.
I got a free cup of coffee (or two), besides. Machine said Starbucks, but it wasn't.
—Steve
      12-06-2017, 04:02 PM   #3
overcoil
Drives: M235i 6spd
glad they replaced battery, once they go into critical low and are attempted to fully recharge the batteries are never 100%
      12-09-2017, 09:13 PM   #4
xantdieselx
Kingslayer
xantdieselx's Avatar
No_Country
411
Drives: 23' M3 Base
Glad you got the battery issue worked out and in a timely manner. I've only had 2 minor problems with my 16' M235i a bad exhaust valve and defective trunk struts. Car has been rock solid otherwise so I don't think you have anything to worry about.
Previous Cars: 2008' 135i, 2010' 328i, 2013' 328i, 2016' M235i, 2017' X1, 2019' M240i
Current Cars: 2019' X3, 2021' M3 Comp
      12-09-2017, 10:55 PM   #5
pikcachu
pikcachu's Avatar
1399
Drives: M235i (F22 Red angel)
what happened with your trunk struts? I noticed mine doesn't open all the way anymore and you kind of have to push it up....
      12-10-2017, 06:04 PM   #6
xantdieselx
Kingslayer
No_Country
411
Drives: 23' M3 Base
Had the same exact issue with mine. When you opened the trunk it would kind of just stay there instead of lifting up. I mentioned it to my SA when the car was in for service and they ordered a set for me. They were back ordered and took like 2 months to come in so I think there must have been a bad batch. You should be able to get them replaced w/o issue.
      12-10-2017, 11:20 PM   #7
pikcachu
pikcachu's Avatar
1399
      04-14-2018, 11:08 AM   #8
1FUNCAR
1FUNCAR's Avatar
Drives: 2018 M240i Coupe
WTF indeed - a bad battery that soon after delivery? Any ideas as to the root cause?
      07-13-2018, 10:23 PM   #9
davejack
davejack's Avatar
Drives: F22
If you want to get the info about BMW battery register and coding guide,maybe this collection can provide some useful information:
https://www.car-auto-repair.com/tag/...-registration/
      08-22-2018, 04:39 PM   #10
biz4two
Drives: 2014 f22 n20 228i
Arrow
WOW!! Hopefully you just got a bad battery...and the car is fine.
biz
2014 BMW 228i f22 n20
Prod.date: 2014-06-27
      08-25-2018, 07:15 AM   #11
Cumberlandjames
Cumberlandjames's Avatar
Drives: 2016 M235i Xdrive cabriolet
Do you have a coupe or cabrio? My Cabrio has never opened when released. Just thought it was something to do with the convertible top?
Any other convertible owners truck lids pop open when released or do they all just lay there?
      08-25-2018, 12:45 PM   #12
pikcachu
pikcachu's Avatar
1399
Coupe
The trunk doesn't open automatically you have to push it. But if the struts are ok once you push it will keep going all the way but when the struts are worn it will stop half way.
Same as when opening the hood
      08-26-2018, 12:20 PM   #13
stevenvillatoro
No idea what caused the issue. My car was a custom order, so it never languished on the dealer lot.
The new battery has been perfect for nine months now, so... case closed.
—Steve
