2Addicts | BMW 2-Series forum Technical Topics Mechanical Maintenance and TSBs: Break-in | Oil & Fluids | Servicing | TSB 6-spd box fluid change at dealer
      02-16-2017, 05:14 PM   #23
overcoil
Drives: M235i 6spd
Originally Posted by delvec03 View Post
Hey guys! So I have a 228 and ordered MTF LT 5, but I believe my recommended oil is MTF LT 3. I can't find 3 anywhere online.
Should return the oil and try and get LT 3? Are there differences? What are they?
Thanks for the help!
-Chris
I'm going to look for my receipt frm dlr on 6-spd fluid change and see if the fluid #'s are listed.
Forgot, your working on a 228
Been a long day
      02-28-2017, 06:17 PM   #24
Paisano
Paisano's Avatar
Drives: M4 Comp
Had the gearbox fluid changed as well and noticed much smoother shifts.
      03-20-2018, 11:58 AM   #25
matthibodeau
matthibodeau's Avatar
Drives: 2024 BMW M4 Competition xDrive
Paisano at how many KM's and what was the cost?
      03-22-2018, 03:27 AM   #26
Hasser
Hasser's Avatar
Isle of Man
447
Drives: 2014 F10 M5
my car is due its service now - so I think I will ask the dealer to do the gear box fluid change also now - after reading this.
cant hurt can it? (except the wallet that is)
main service, so plugs, filter and engine oil to change.
been quoted £450 here in the uk for the service. would need to add the gearbox fluid change on top of this.
car is march 2014 build so 4 years old now with 17k miles.
2014 M5
1990 E30 318i Touring
1999 E38 728i -sold
M235i - sold
Activehybrid 5 - sold
      03-22-2018, 07:10 AM   #27
delvec03
Drives: 228i Sport/ DSB
I've given it some thought and I'm going to do mine myself. you can find mtf-lt-3 online for $40/qt. I also snagged a magentiezed drain plug which should help with life of the transmission.
one day on the jacks and I can do my tire rotation at the same time. well worth it.
2015 228i manual, btw
      03-22-2018, 07:48 AM   #28
overcoil
Drives: M235i 6spd
If you get an oil analysis kit for gearboxes - and ask the tech to grab a sample mid stream while emptying - you can kind of verify the service is actually being performed. And you get to analyze the gearbox.
      03-22-2018, 11:41 AM   #29
SteveInfante
NewFinishColumbia/detailer
SteveInfante's Avatar
Drives: 2015 F31 xDrive
There has been some discussion about LT3 versus LT5. LT5 is recommended for both the P car PDK and the BMW DCT, both of which are manuals at the core. You can get LT5 Pentosin on Amazon pretty cheap. It holds 1.4L per the TIS. This is the route I'm going to go very soon. I'm also sending a sample in with my engine oil into Blackstone as well.
78' Honda CB400A project
      03-22-2018, 05:40 PM   #30
delvec03
I've been mulling this for months. my transmission specifically says Lt-3 only. which made me pucker and not spring for the lt-5.
do you have any info on one over the other and why? I've seen that lt-5 is for 235 and lt-3 in my 228.
      03-22-2018, 06:19 PM   #31
SteveInfante
I believe there was discussion in the forums that the LT3 was originally for the M235 6MT as well and then it was changed to the LT5. My thoughts are if it was changed from 3-5 for that BMW manual of the same era then why not.
      03-24-2018, 11:44 AM   #32
Hasser
Hasser's Avatar
Isle of Man
447
Drives: 2014 F10 M5
what volume is required for a gearbox oil change?
2014 M5
1999 E38 728i -sold
M235i - sold
      03-24-2018, 02:45 PM   #33
delvec03
been seeing 1.4 qts for manual.
      03-24-2018, 02:46 PM   #34
Hasser
Hasser's Avatar
Isle of Man
447
Drives: 2014 F10 M5
thanks. need to convert to litres
2014 M5
1999 E38 728i -sold
M235i - sold
      03-26-2018, 03:01 AM   #35
Hasser
Hasser's Avatar
Isle of Man
447
Drives: 2014 F10 M5
1.32 litres.
2014 M5
1999 E38 728i -sold
M235i - sold
      03-26-2018, 01:43 PM   #36
MarcoZandrini
Drives: 2018 M240i
-Chris
Contact ZF USA.
      04-05-2018, 12:43 PM   #37
Hasser
Hasser's Avatar
Isle of Man
447
Drives: 2014 F10 M5
confirmed 1.2 litres for the 6MT gear box
6.5 litres for the engine oil.
2014 M5
1999 E38 728i -sold
M235i - sold
      04-12-2018, 01:22 PM   #38
MarcoZandrini
Drives: 2018 M240i
-Chris
https://www.eeuroparts.com/Parts/141...AaAlnoEALw_wcB
      04-12-2018, 09:15 PM   #39
SteveInfante
This is going in tomorrow.
      04-13-2018, 06:44 AM   #40
delvec03
you'll be super happy you did it. swapped mine, did lt3, and it's worlds better that it's ever shifted! happy transmissions, happy driver!
      04-17-2018, 04:47 AM   #41
Hasser
Hasser's Avatar
Isle of Man
447
Drives: 2014 F10 M5
got some of this for the manual gear box fluid change.
hopefully the correct fluid.
as it does state for BMW cars.
any opinions?
2014 M5
1999 E38 728i -sold
M235i - sold
      04-18-2018, 04:30 PM   #42
SteveInfante
That looks like a good option as well.
      04-24-2018, 07:42 PM   #43
SteveInfante
Here's what I got back from Blackstone on my 6MT oil sample. I had 71,321 miles on this fluid.
