2Addicts | BMW 2-Series forum Technical Topics Wheels and Tires -- Sponsored by The Tire Rack Will m14x1.25 to m14x1.5 conversion bolts be okay?
      06-30-2020, 04:08 PM   #1
Rahstyles.Com
Drives: E93 M sport
It's impossible finding spike lugs for my m14x1.25 converted bolts
So I think I'll have to change then again cause the common size is m14x1.5
Now will this be a issue for mounting the wheels?
I'm not familiar with bolt sizes and I don't know how much of a difference 1.25 vs 1.5 will do?
      06-30-2020, 09:04 PM   #2
K8_M235i
K8_M235i's Avatar
Drives: CM E36
If you are saying that you have a stud kit that is m14x1.25 you can not use m14x1.5 nuts on them. Thread pitch might seem to be close enough, but they will have a lot of resistance and strip.
There are stud kits that convert the outer part to m14x1.5 though if your only option for nuts is m14x1.5
2015 F80 M3 DCT, Carbon Roof
1998 S54 E36 M3 BMWCCA Club Racing #532 CM
1995 E36 M3 Sunbelt S52
      07-01-2020, 09:41 AM   #3
Maynard
Drives: 228iX & M2C
Tom at Core Motorsports was very helpful with some of my Q's about wheel lugs/bolts, might give him an email to see what they suggest - they mostly do conversions to press-in studs, but very knowledgeable. When I need to pull hubs for anything I'm going to go for a conversion. Bottom line is that any screw-in studs are going to be inferior to bolts in terms of strength, so you may be better off staying with lug bolts (but longer if you are using spacers). www.Core4Motorsports.com
