2Addicts | BMW 2-Series forum Technical Topics Wheels and Tires -- Sponsored by The Tire Rack KONIG Hypergram Fitment
      06-11-2020, 06:16 PM   #1
ghost.M
ghost.M's Avatar
Drives: 2015 BSM M235i 6MT
Does anyone have experience with these? They are flow formed, come with 72.56 center bore, and are just under 17/18 pounds each for the 17x8/9 both ET 35. A full set of four can be had for <$900 and I'm considering running 255/40 on 17x9's for the track if they will fit.
The car is having KW V3's and GC Camber plates installed now and I plan to run -3.2/-2.6 F/R Camber with 0 toe. The front may need small spacers (3-5mm) to clear the KW's (front fenders are already rolled+) so I'm mostly concerned about the rear. Has anyone run a lower offset like this on 17's? I'm not opposed to having them shaved 3-5mm if needed for outer clearance If needed.
I'm deciding between getting these + 19's for the street, or just getting 18x8.5/9.5 EC-7's as a compromise and running them street and track with an HD 200TW tire like the RS4. Right now the EC-7s are winning out as they are proven on the F22 platform but I know after burning through the 200TW's in 10K miles or less I'll wish I had a separate track wheel/tire set which is why I'm looking at these.
https://konigwheels.com/wheels/flow-...els/hypergram/
      06-11-2020, 08:57 PM   #2
K8_M235i
K8_M235i's Avatar
Drives: CM E36
My dad runs them on his focus rs during the winter. They are a decent value wheel.
Fitting 17s has a lot to do with the barrel design more than anything else. Some fit and some don't fit.
In your case, that rear offset will give you trouble. For a 9" wide wheel you'll want to be around +40 to +50
For not that much more $ you could get a set of bimmerworld TA5r wheels. I just got a set of 17x9 +42 for my m235. They are around 17.5 pounds, flowformed, and have a knurled bead seat. They clear the calipers with plenty of room to spare. I am running -2.5 f and -2 r camber with 245 square.
2015 F80 M3 DCT, Carbon Roof
1998 S54 E36 M3 BMWCCA Club Racing #532 CM
1995 E36 M3 Sunbelt S52
230iZTR315.50
      06-12-2020, 10:29 AM   #3
ghost.M
ghost.M's Avatar
Thanks for the background and good call on the TA5r's. They seem to be exactly what I'm looking for. Are you on OEM dampers or coils? Did you use a spacer in front?
Thanks!
      06-12-2020, 10:34 AM   #4
K8_M235i
K8_M235i's Avatar
Drives: CM E36
I'm running a 10mm spacer up front, so an overall offset of +32. I'm on oem struts with dinan springs.
ghost.M22.50
