2Addicts | BMW 2-Series forum Technical Topics Wheels and Tires -- Sponsored by The Tire Rack TR Motorsport C4 with 245/40/17 square setup
      05-16-2018, 11:19 PM   #23
ChrisFulton
Drives: m235i
Originally Posted by jmwilson125 View Post
What is your offset?
Et40
      05-18-2018, 11:01 AM   #24
jmwilson125
Drives: 2016 M235i
Originally Posted by ChrisFulton View Post
Et40
Just put mine on they seem not to be rubbing.
Et46 (measured by me roughly) 8" rim
      05-30-2018, 12:05 PM   #25
PLF69
PLF69's Avatar
3768
Drives: 2023 M3
Love the look ! The steering and grip feels much better than my oem 19 inch staggered setup.
Fun/HPDE: 2023 M3 6MT Individual Malachite
Past:2023 M4 CSL, 2022 M4C Vert, 2020 M340i, 2018 M2, 2015 M235i, 2008 135i 550whp
Daily: 2023 X5 45e
Daily/Family: 2021 Atlas Cross Sport 3.6
      06-04-2018, 02:02 PM   #26
ChrisFulton
Drives: m235i
Looks good!
I'm very happy with mine too.
If you track it, remove the center caps. I forgot and lost 3.
      06-04-2018, 06:19 PM   #27
jmwilson125
Drives: 2016 M235i
Update, this setup does RB on the outside front, or I should say did. Seems ok now
      06-04-2018, 06:45 PM   #28
Maynard
Drives: 228iX & M2C
Those look so good. May break down and get a set for the next track day, to save my dailies.
      06-12-2018, 08:43 AM   #29
PLF69
PLF69's Avatar
3768
Drives: 2023 M3
Anyone knows where to buy replacement center caps ?
Daily: 2023 X5 45e
      06-12-2018, 09:21 PM   #30
Cycle Pilot
Drives: 2019 M2C
Probably Tire Rack. Otherwise, PM me.
      06-12-2018, 09:26 PM   #31
ChrisFulton
Drives: m235i
Tire Rack has them.
$4
I lost 3 first track day & threw the 4th in the trash.
      06-13-2018, 08:45 AM   #32
PLF69
PLF69's Avatar
3768
Drives: 2023 M3
Thanks ordered 4 but since I'm in Canada with shipping and fees ads up to $46 USD
Daily: 2023 X5 45e
      06-13-2018, 11:49 AM   #33
aerobod
aerobod's Avatar
3626
Tire Rack has them.
$4
I've found that plastic centre caps melt from brake heat migrating through the hub into the wheel centres during track days, one additional check before taking the car out is to remove them. On my Caterham the rear wheel hubs are particularly prone to melting the centre cap tangs before they fly off, causing them to become track debris and potentially being given a black flag.
      06-13-2018, 01:19 PM   #34
dradernh
dradernh's Avatar
4413
Drives: 2017 M240i
The first time one came off a car of mine, a track worker saw it, retrieved it, and brought it over to me saying "We just assume all you guys know to take them off for the track." Of course, he was thinking in terms of their having to clean junk off of the track.
      09-05-2018, 11:37 AM   #35
Razzback
Drives: 2018 M240 XDrive
Hey, I was researching a 245 square setup and came across this thread. Happy it works out! Do/can you use any spacers in the rear to make the tires flush with the fender? I think people use 10-20mm on stock rear wheels, but I've never messed with it.
M240X /// DINAN /// VMR
      09-06-2018, 04:24 PM   #36
Quicksilver_M235
Marshal Of The State
Quicksilver_M235's Avatar
24
Drives: 15' Silver Metallic M235i
Originally Posted by nubbster927 View Post
I remember when checking my speedo against GPS, the speedo read ~4-5 mph higher than the GPS at about 80 mph, whereas the stock tires read within 1-2 mph or so.
As far as ABS, I didn't notice a difference. Brakes still chattered like normal, I just stopped much quicker than before with all that new grip.
I would think you should be able to re-program your wheel diameter via Bimmercode? Am I wrong?
      09-07-2018, 10:41 PM   #37
nubbster927
Drives: AW M235xi
I've never messed with spacers either. It looks pretty flush to me just right out of the box. But the setup works great!
      05-17-2020, 05:28 PM   #38
SkyeC
Too many cars, not enough time
43
Drives: 17 m240i
Sold! Amazing value on these wheels and you can get 245/40 RS4s for $140 each on TR right now.
Going w/ black on my estoril m240.
      05-17-2020, 11:00 PM   #39
Solid67
Drives: 2019 M240i xDrive MP Edition
Would a 255 square setup be possible?
2019 M240i M Performance Edition / xDrive / ZF8 / BM3 Stg 2+ E30 / xHP Stg 3 / Dorch Stg 2 HPFP / Evolution Racewerks Catless Downpipe / MPPSK Exhaust / FTP Drop in Filter / FTP Intake Pipe / FTP Chargepipe / NGK 94201 Spark Plugs .022 / Michelin PS4S - 225/35/19 + 245/30/19
      06-26-2020, 09:43 AM   #40
nubbster927
Drives: AW M235xi
Definitely possible, I've seen it in person and seems like other guys on the forum run it without a problem. But I think you need some additional camber, and probably a wider wheel than 8 inches to pull it off and get the clearance you need.
Solid67187.00
      07-10-2020, 08:47 AM   #41
PeanuKeeyes
PeanuKeeyes's Avatar
366
Drives: E34 | MX5
Considering this setup: 245/40 r18 ET40 With the C4 TRMotorsports. Mostly because I track so infrequently and want them as full summer setup and the wheel gap with 17” looks a little too large for my preference. Does anyone know if the 18” vs 17” present fitment issues? Edit: on stock suspension *
      07-10-2020, 11:57 AM   #42
TakoMako
Drives: M240i Xdrive
255 is definitely doable. You just need at least 2.3* of negative camber. Yes, I stuffed a 255/40R17 RE71R on it.
The car is now on KW clubsport, and has 3.3* of camber, and I have a set of NT03RR 18x9 ET45 with 17.5mm spacer with Hankook RS4 in 255/35R18 on it. It fits.
      07-25-2020, 02:34 PM   #43
PLF69
PLF69's Avatar
3768
Drives: 2023 M3
Looks absolutely amazing. I don't know how I've missed this thread.
I now have an M2 since 2018, things are a bit more expensive but we can run up to 265F and 295-305 rear, grip is insane..
Daily: 2023 X5 45e
      07-25-2020, 04:44 PM   #44
TakoMako
I have seen 285 square on a M2 during autocross.
