06-17-2020, 09:32 AM | #1 |
Rep 85
Autophix 7910 Brake Bleeding DIY?
Yep, tried to search. Got lots of threads on bleeding (thx!) without running the ABS. Any links to threads that describe when/how to cycle the pump with whatever type of controller? Maybe even sticky the best bleed how to?
Thx in advance. |
06-17-2020, 10:34 PM | #2 |
Rep 85
https://www.newtis.info/tisv2/a/en/f...nce/1VnXvjGCJ0
https://www.newtis.info/tisv2/a/en/f...nce/1VnY1gRBo9 Not the easiest to follow, but something. |
06-18-2020, 07:36 AM | #3 |
Rep 2,870
Those links describe simple flushing, but not the ABS clearance. I believe that this link does describe that (I've heard it called ISTA, but here it is ISID).
https://www.newtis.info/tisv2/a/en/f...nents/GfgD7vNY (after a full bleed) Bleed the rear axle brake circuit (same for front). Connect bleeder hose with collecting tray to bleeder valve on rear right brake caliper. Open vent valve. Run brake bleeding procedure with ISID with vent valve open. After completing routine, press brake pedal 5 times to floor; clear and bubble-free brake fluid must flow out. Close vent valve. Repeat procedure at rear left. |
