2Addicts | BMW 2-Series forum Technical Topics Suspension | Chassis | Brakes Stock 18s with Dinan Springs and F8x LCA?
      01-24-2020, 12:52 PM   #1
tcollier91
Drives: M240i
Does anyone have any pics of stock 18s (I have the staggered set) with the dinan springs, bump stops, and F8x LCA? Seems like most people have aftermarket wheels, but I'd rather not swap mine out right away. Just didn't know if the car looks awkward lowered on 18s.
      02-04-2020, 12:57 PM   #2
JoeCasey89
Drives: 2016 M235I
I dont have the lca's but im on dinan springs
      02-04-2020, 01:00 PM   #3
JoeCasey89
Drives: 2016 M235I
Stock wheels and tires.
      02-05-2020, 05:11 PM   #4
Stock 19'' 624m +10/15mm spacers w/ Dinan Spring + M4 LCA/TS, no rubbing.
      06-14-2020, 11:14 AM   #5
gosi
Drives: M240
Dylan86, how well do Dinan springs get along with the stock dampers, since I’ve seen that you track your car? I’m interested in a stiffer ride but a bit skeptical since I’ve driven a car with mismatched dampers and springs before. How is the handling in Sport mode?
      09-12-2020, 12:32 AM   #6
tcollier91
Drives: M240i
Looks awesome. 10mm front/15mm rear spacers? Some of the guys in the LCA thread make it sound like you'd be close to rubbing just running the LCA+TS on 19s!
      09-19-2020, 09:39 AM   #7
The outside diameter on the 19's should be much if any different than the 18's with the appropriate tire conversion (235/40/18 --> 225/40/19 for ex.). And yea this was with 10mm/15mm f/r
