01-18-2019, 04:26 PM | #1 |
Rep 184
Is 245/40/18 in rear ok, instead of 245/35/18?
Greetings all,
Did a search and came up with everything but my specific question... My '19 M240i xDrive was built with the staggered 18" wheels/tires, specifically, 225/40/18 (front) & 245/35/18 (rears). Can I change the rear tires to a 40 aspect ratio tire? In essence, I want to purchase A/S tires & would like to just increase the height of the rear tires from a 35 aspect ratio to a 40 height - 245/40/18, instead of the stock height of 245/35/18. Will this cause any issues with my xDrive and/or performance issues? TYIA/Cheers, B
Previous BMWs: '87 325is; '06 X3; '09 X3; '11 328i x-Drive; '12 R1200 RT; '13 128i; '13 X3 35i MSport
Other/Current: '19 Porsche 991.2 TT; '21 Jeep Wrangler JL80A; ‘23 Lambo Huracan EVO RWD |
01-18-2019, 06:12 PM | #2 |
3626
Rep 3,592
If you increase the front aspect ratio too, shouldn't be a problem. 225/45-18 on the front 245/40-18 on the rear will keep the tyre rolling diameters close. On the stock wheels the offsets should prevent any tyre contact with body work, but I would confirm with your tyre fitter that there is no issue. I run 225/45-18 winter tyres on 18x8" ET45 wheels at all four corners without any issues, the speedo now reads 1% low compared with 3% high with the stock tyre sizes.
BenDiem76.00 |
01-18-2019, 07:19 PM | #3 |
Rep 823
You could also go with a 235/40/18 on the rear and the overall diameter between your front and back would only be .3" vs a .6" with a 245/40/18. Either way will work but I'd personally go with the 235 because I'd like to be close as possible to the front diameter.
BenDiem76.00 |
