2Addicts | BMW 2-Series forum Technical Topics Wheels and Tires -- Sponsored by The Tire Rack 18X9 - 255 Front Possible
      01-10-2019, 10:20 AM   #1
Taskmaster
Japan
2465
Drives: M235i 6MT / E92 328 Msport 6MT
Hey guys,
I ran across this thread while looking for a 18X9 Square setup
https://www.1addicts.com/forums/showthread.php?t=216972
Originally Posted by Fair View Post
We test fit a set of 18x9" (ET41 D-Force LTW5) onto a customers 135i recently. Seemed to work fine to me... :iono:
Any car this heavy needs as much tire as you can possibly stuff underneath it. The rear can handle more than a 9", but then you're going back to a staggered set-up which means more understeer. BMWs work best with the same wheel/tire widths front and rear. The 18x9 wheel on the back of this car would have worked better with more backspacing, pushing the wheel inboard more. From my testing, I think an 18x9 ET45 to ET48 offset would be ideal out back (and the same set-up with a 10mm spacer up front would make tire rotations easy).
An 8" wheel should fit with ease. That's still too narrow, but it would work. Anything to get the boat anchor factory wheels + run flat tires off these cars is a good thing.
48.3 pounds for the OEM front wheel + a replacement tire, and that's not even a run flat (which are even heavier, and ride/handle worse). That is abysmal for such a skinny wheel and tire. Those brakes are also MASSIVELY heavy. Its no wonder why these cars push 3450 pounds... but it can be fixed.
For me, the appeal is to have a slight stretch on the rubber for fitment and better sidewall support vs the 18X8.5. Would something like this work for the F22?
      01-10-2019, 02:51 PM   #2
gtmax500
Drives: 2016 MW M235xi
2016 BMW M235xi  [0.00]
I've been researching wheel fitments for our 2 series for quite a while before I settled on 17x8.5 with 255 square for my track set up. I would be HIGHLY surprised if you were able to fit a 18x9 in the front even with some serious camber dialed in.
I believe 18x8.5 255 square with at least 2.5* camber is about as wide as we can go without rubbing. Even that is still wheel/offset dependent.
I can't quite remember but I don't recall coming across anyone with 18x9s up front but I could be wrong.
      01-10-2019, 03:13 PM   #3
dradernh
dradernh's Avatar
4384
Drives: 2017 M240i
I went with 17X9 ET42 -1.9° with no spacer and a very slight fender roll up front.
      01-10-2019, 03:36 PM   #4
Taskmaster
Japan
2465
Would 18's work equally as well as the 17s?
      01-10-2019, 03:59 PM   #5
dradernh
dradernh's Avatar
4384
Drives: 2017 M240i
I don't know, but I think it's the size of the tire that is the limiting factor (i.e. that's what rubs, whether on the inside against the suspension or on the outside against the fender or the fender liner).
      01-10-2019, 04:04 PM   #6
Taskmaster
Japan
2465
Have a picture how your tire and wheel look currently mounted?
      01-10-2019, 04:35 PM   #7
dradernh
dradernh's Avatar
4384
Drives: 2017 M240i
Below are the only shots I have with the 17X9 wheel and the 255/40-17 tire on the car.
The rear is 18X9½ ET58 -1.6° with a 5mm spacer and a 255/35-18 tire. The drop is 1¼" in front and 1" in the rear.
Taskmaster2465.00
      01-10-2019, 05:50 PM   #8
Taskmaster
Japan
2465
Awesome. Awesome! Thank you!
      01-11-2019, 09:11 AM   #9
cxp213
cxp213's Avatar
313
[IMG]http://u.cubeupload.com/EdWinter377/f36M240iShowingFitmento.jpg[IMG]
[IMG]http://u.cubeupload.com/EdWinter377/M240iwithApexWheelsT.jpg[IMG]
[IMG]http://u.cubeupload.com/EdWinter377/M240iShowingFitmento.jpg[IMG]
Nice to see someone running 255s all around. What is your full suspension and alignment spec?
      01-11-2019, 12:48 PM   #10
dradernh
dradernh's Avatar
4384
Drives: 2017 M240i
The build is detailed here: https://www.2addicts.com/forums/show....php?t=1532418
      01-22-2019, 01:46 AM   #11
230iZTR
230iZTR's Avatar
316
I’ve been looking at 3 different width/offset combinations to fit a 255 square setup (either Michelin Sport Cup 2 or Bridgestone Re-71R) with Vorshlag camber plates are hen the tax returns come in, and I’d like to see if anyone has tried these before:
1. 17x8.5et40 (concerned it’ll poke way too far out in the rear)
2. 17x9et42 (concerned it’ll rub in front)
3. 18x9et42 (would open up tire selection, but again could rub)
How much camber would I need to make such a setup work? Would rolling the fenders help? Would it be at all streetable?
      01-22-2019, 12:13 PM   #12
Taskmaster
Japan
2465
I'm not sure specifically, but expect to run over 2.5* which is streetable. I saw a few track builds that have 18X9 42 on ARC8s
      01-25-2019, 11:45 AM   #13
bbnks2
Drives: 135i N55
You can fit 17 or 18 x 9 wheels with 40 series or 35 series tires, respectively. 17's with 255/40/17 is the cheaper and lighter tire/setup which is why it's the go-to over 18's. You need ET38 or lower to avoid rubbing on the strut which is why all those people with ET42 or ET45 wheels have small spacers. You will also need 2.0*+ of camber and a fender roll. It fits, but it takes a little work.
Some people claim to not need the fender roll. I think ride height plays a factor in this...
The reason why ET45 is a popular offset is because you need a higher offset in the rear. 17x9 ET45 might rub on the outside fender a bit. Again, ride height and camber dependent. If you want to keep rear camber in check at like 1.5-2.0* you might need to roll the rear fenders to fit a meaty 255. Or, run a higher offset wheel in the rear. Problem with running a high offset in the rear is that the track width difference starts to impact handling characteristics and you end up with a drift car setup lol
      01-25-2019, 11:51 AM   #14
Taskmaster
Japan
2465
The reason why ET45 is a popular offset is because you need a higher offset in the rear. 17x9 ET45 might rub on the outside fender a bit. Again, ride height and camber dependent. If you want to keep rear camber in check at like 1.5-2.0* you might need to roll the rear fenders to fit a meaty 255. Or, run a higher offset wheel in the rear. Problem with that is that the track width difference starts to impact handling characteristics.
Tire size will be 255/35 or 255/40 - I'm leaning on 18s purely for aesthetic reasons. It looks like a 5mm spacer will likely be needed with anything ins the 40-45ET.
It will be DD with about 2* camber, or 2.5* if I can tolerate it.
      01-30-2019, 10:38 AM   #15
Hpirx
Drives: 2022 M240 xDrive, BGM
So I have a set of square Apex Arc-8s
17x9 ET 30 shod with Bridgestone Potenza S04s 255x40-17 left over from my 2008 E90. I'd love it if I could fit these wheel to my new '19 M240i xdrive. Stock wheels definitely undertired for this car and would be relegated to winter snows. Will the et 30 offset be an issue? Will it fit calculators show reasonable strut clearance with some poke, which I could live with if it doesn't look too ridiculous. The Bridgestones are also at the end of their life, so new tires are also a consideration in the calculation. Any one running a similar setup? Mods, ie fender roll, camber plates necessary for it to work? I will probably just try them on in the spring to check any way, unless the consensus is that this definitely won't work. BTW I'm partial to a meatier fitment rather than worrying about fender gap. Thanks.
Retired: '08 335xi E90. "Long may you run."
Retired: '19 M240xi "You also"
      01-30-2019, 10:51 AM   #16
bbnks2
Drives: 135i N55
Try it and let us all know? I was replying to the E82 fitment he was quoting. I am pretty sure 2-series fitment is more similar to 1-series than it is the 3-series. I think ET30 will hit the fenders both front and rear but get back to us with what you find.
      01-30-2019, 10:53 AM   #17
Hpirx
I will, but probably not until May!
