2Addicts | BMW 2-Series forum Technical Topics Wheels and Tires -- Sponsored by The Tire Rack Will 225/40 front fit on the staggered rear wheel?
      12-24-2018, 08:24 AM   #1
keving75
Drives: M235
I need new tires for the M235 . I have the staggered setup with 225/40 Front and 245/35 Rear.
This is a daily driver for the wife, not a track car, so I wanted to get a good all season tire that can be rotated. Looking at the Michelin A/S 3+ and they are easier to find in the 225/40 size.
It looks like I can install the front 225/40-18 front size on the wider rear wheel, but I wondered if this was a common setup for anyone??
Any issues?
      12-24-2018, 09:27 AM   #2
aerobod
aerobod's Avatar
3624
Any issues?
No issues in fitting the 225/40-18 tyre to the rear wheel, but you will have to remount the tyres to rotate them or use a spacer on the rear wheels if used on the front, as the ET is too high.
      12-24-2018, 01:41 PM   #3
hwntime
hwntime's Avatar
270
Drives: F22 Raptor
Your rear wheels will look very tucked. A 10-15mm+ spacer would be needed to get you near flush, and also that rear tire will look really stretched with that racerboy look. Find a second pair of 18x7.5 to run square on 225's. They're constantly available for sale here in the classifieds.
      12-24-2018, 06:12 PM   #4
keving75
Drives: M235
Thanks for the responses. You confirmed what I wanted to know about the best way to get 4 equal size tires/wheels.
      01-18-2019, 12:59 PM   #5
marcthedark
Drives: M240i xdrive Convertible
A) front is as from the factory
b) 225 on 8 inch is "stretched" boyracer? 205 on 8 inch are kinda stretched but nothing extreme
Rim width Ideal tyre width
7,5 Inches 215 or 225 mm
8,0 Inches 225 or 235 mm
      01-18-2019, 01:14 PM   #6
hwntime
hwntime's Avatar
270
Drives: F22 Raptor
Yes, it will look slightly stretched. I'm on 18x8 squared with staggered tires 225/40 front and 245/35 rear (Mich AS3+) and you can see the difference between the two. I personally like the flush look of the 245 better. It's all preference.
      01-21-2019, 10:00 AM   #7
marcthedark
That is why I said "slightly stretched" (and as you implied that depends on the tire too as some run wider than others). 225mm = 8.8 inches so in theory wider than the rim
But boy racer stretched is a 195 on a 8 inch
