2Addicts | BMW 2-Series forum Technical Topics Wheels and Tires -- Sponsored by The Tire Rack BIGGER WHEELS/TIRES FOR 2019 M240i?
      12-23-2018, 09:29 PM   #1
Think-U-R-Mario-Andretti?
M240iCVDriver
Drives: 2019 M240 CV
Hi Everyone,
I recently got a 2019 M240 Convertible with the 405 wheel & tire package.
Front: 19 x 7.5 405 M Performance wheel with 225/35/19 HP Run-Flats
Rear: 19 x 8.0 " " 245/30/19 "
I want to fit bigger tires/wheels and switch to non run-flat
GOAL:
Front: 245/35/19 Michelin Pilot Sport S4 Non Run-Flats
Rear: 265/30/19 " "
QUESTION:
1. Has anyone here fit this size tires successfully onto this car?
2. Front - what size wheel 19 x 8.0 or 19 x 8.5 with what Offset Et.?
3. Rear - " 19 x 9.0 or 19 x 9.5 " ?
4. Which Brands have the right combination?
DINAN:
They are offering a BBS CR-I Wheel set
Front: 19 x 8.0 Et. 45 but only 235/35/19 Michelin's
Rear: 19 x 9.0 Et. 48 for 265/30/19
AC SCHNITZER
they offer wheels, but don't specify the tire size
Front: 19 x 8.5 Et. 43
Rear: 19 x 9.5 Et. 50
Anyone here who knows if they fit and what wheel brand, size and offset is needed?
Thank you
Matthias
      01-03-2019, 10:11 PM   #2
john16443
Drives: 2017 M240i
Sounds like you may want to spend some time using the calculator from the 3 series site...
https://www.e90post.com/forums/forumdisplay.php?f=12
This should answer your questions on what will fit and what offsets will do to clearances.
Your 245 fronts need a minimum 8" wheel
Your 265 rears need a minimum 9" wheel.
Play with the calculator to see what works best for you.
