11-20-2018, 09:54 AM | #1 |
Rep 49
GFB DV+ and Intake heads up
So I have installed a JB4, VRSF FMIC, Charge pipe and GFB DV+(both springs installed), Burger Intake. I have DP & boost pipe just haven't installed yet wanted to find bugs before I install more.
Ive got the M235i, auto trans and running map 1. I will get a code 123511 sluggish wastegate ONLY in Sport mode. Usually when on a long decal from high rpm. I think it is because the DV+ modulates pressure more so vs full dumping like factory. And when in sport mode the throttle response is sharper, so when under decal the DV+ holds slightly higher pressure and throws a code. I know there is a warning in the instructions that it may throw a code but doesn't say what the code may be. I wanted to share what I have found in case others are looking into this mod. I will likely remove the larger spring so the DV+ acts like a factory diverter valve. I like the sharp throttle response and not willing to give it up. Also if you have the Burger Tuning intake. I had to modify the mounting bracket on the air box_cut about 3/4" off and used 1 mount bolt in order to lower the intake tube). The MAF sensor sits much higher than stock and when the hood was closed it would be pushing on the sensor connector excessively in my opinion. The insulation on the hood had an indentation where the sensor was pressing on the connector. I have seen some grumblings about issues with this intake and perhaps the connection on that sensor being squished & under pressure by the hood is causing the problem. Car runs strong now, looking forward to DP. Not looking forward to DP fix issues. Doesn't seem like there is a common for sure fix yet. I bought JB4 thinking that would be the solution before finding out that isn't the case anymore. And the work around hides all codes, don't want that. |
11-20-2018, 03:08 PM | #4 | |
Rep 5,369
11-20-2018, 03:19 PM | #5 | |
Rep 49
maybe
This is a fresh install with only 50 miles or so. If it has been there awhile I would be more inclined to agree. I can get the light to come on is predictable and repeatable. Im not saying your wrong, but with a brass piston in an aluminum housing Im not on board saying it is binding just yet.
Id like to hear from others with the DV+ installed, to know if they have issues as well. Quote:
11-20-2018, 03:54 PM | #6 |
Rep 63
FWIW, I had a GFB DV+ installed on my 2012 C250 Coupe a few cars ago. I had the DV on there for around 20k miles before trading in. Granted this was a Mercedes, it never appeared to be stuck or throw any codes for that matter. I never had to go back out and lubricate the DV after initial install. It worked great and I look forward to adding one to my 2 series once I get myself to attempt the install.
2015 435i (current): VRSF Catless Downpipe, Bootmod3 Stage 1, xHP
2008 Corvette (sold):Vortech supercharger, ported/built heads, catless 2015 M235i (sold): CTS Turbo Intake, VRSF Catless Downpipe, CSF FMIC, MPE, xHP, Bootmod3 Stage 2 E30 |
EVEda235i90.50 |
11-21-2018, 07:50 AM | #7 |
Mr. Clutch
91
Rep 245
Drives: 2015 M235i
Pro tuning freaks makes bm3. The best flash tune platform out there. I used to be. Jb4 fanboy until i got bm3. Everything is better.
https://www.protuningfreaks.com/prod...5i-x3-x4-x5-m2 Runs with your laptop or with your phone if you get the wifi device. Device is $300 from them or you can make your own (identical to there's) for $60 with diy thread on here somewhere.
Quiet M235i
jondagger90.00 |
11-21-2018, 09:51 AM | #8 | |
3441
Rep 79,211
11-21-2018, 11:02 AM | #9 |
Rep 49
i hear ya
Personally I think the issue I am having is the warning they mention in the instructions that it may throw a code on some cars. ITs not all the time just in sport mode under long decels. So if I run it up in manual trans mode lets say in 4th gear to red line and then let off the gas and coast down, around 4k rpm car will throw code then go limp. If I just use it(sport mode) to launch from a dead stop then shift into comfort mode before revs come down to low, or get back on the gas a little and let it shift itself down in the revs. No problem. Like I said I can replicate the issue and I know when it comes in. I just wanted to throw it out there for feedback and give heads up to others. I know how frustrating it can be to have an issue and not find any reference to it anywhere. Or some old vague reference.
11-21-2018, 11:07 AM | #10 | |
Rep 49
please clarify
**Cold start cat heat cycle and cat efficiency check removed (for off-road use)** Is this the option that gets rid of the CEL for catless DP? |
11-21-2018, 11:56 AM | #11 | ||
Mr. Clutch
91
Rep 245
Drives: 2015 M235i
Or you can buy this https://www.protuningfreaks.com/coll...a-all-f-series You plug the enet cable into it and then connect it to your phone's hot spot. Then you can control everything thru the bm3 phone app Yes it has the dp fix option. Adjustable burbles, boost by gear, top speed limiter removal, etc...
Quiet M235i
jondagger90.00 |
11-24-2018, 10:27 AM | #12 |
Rep 49
update to DV+
So I thought I would give a quick update on the DV+
I put the jb4 in disabled(Map0) and tried to replicate the throwing of the code. Couldn't do it. SOOOO I went back to Map1, tried to replicate the problem. Couldn't do it. So I'm maybe the car needed time to adapt. I didn't reset the adaptive settings via the gas pedal to the floor and push start button, or however it goes after installing everything. I'm thinking maybe now I should have. Thanks for the info on the coding. I think that will be my next step. I want to drive the car for a week or 2 and try to get the code to come back before I move on the DP. |
11-24-2018, 04:07 PM | #13 |
Rep 1,184
Hey, I got this same code a few times. It ended up being my ewg connection. Somewhere something must have been shorting out.
I pulled the ewg connector and peeled the wires apart and individually wrapped both in tape. Then wrapped both together with heat tape and reinstalled. I have not gotten the code in over a year now. Also the whatever the issue was, it was very sporadic, but seemed to happen more often when the car was very hot. There were no obvious spots where wire was exposed or the insulation looked damaged |
11-24-2018, 05:14 PM | #14 | |
Rep 49
good to know
11-27-2018, 03:37 PM | #15 | ||
3441
Rep 79,211
12-01-2018, 01:08 PM | #16 |
Rep 49
update
Seems like the problem of the reandom sluggish wastegate error code is back. Happened in an unexpected situation and in comfort mode.
BUT, I removed my JB4 and installed VRSF downpipe(after the codes reemergence). Reset adaptations via gas pedal process. I then went for a few test drives and no DP CEL. I removed the JB4 planning to do a flash instead. I bought the car used and now I am wondering if it has already been flashed since I got no DP CEL. This might be the reason I am having wastegate codes. Running the JB4 with with a flash and not knowing it, maybe? |
12-03-2018, 02:49 AM | #17 |
Rep 373
here in South Africa many people run a dp (my self included up until 2 weeks ago when i went FBO) with out throwing codes at all with the stock tune
'14 F20 M135i EWG FBO:// INJEN INTAKE // PURE INLET// TURBOSMART BOV DUAL PORT // //CSF INTERCOOLER // ER CP // SNOW S2.5 METH KIT // B58TU HPFP // NGK 97506 // ER DP // TMSS MID PIPE //MPE // MPBBK // UR STRUT BRACE // BM3 CUSTOM JORDAN E85 TUNE // XHP STAGE 3 // |
12-03-2018, 09:15 AM | #18 |
Rep 1,931
check all your wires for shorts...
You need to hook up ISTA and read... Everything else is a monkey fking a football. Trust me.
www.nybmwcca.org
12-03-2018, 11:10 PM | #19 | |
Rep 9,004
12-13-2018, 08:47 AM | #21 |
Rep 49
Changed to mhd, stage 2+. Havent had the DV+ issue. And i can really hear the wastegate now, never heard it before. I did remove the jb4 so its a stand alone mhd flash. This option got rid of the dp cel light & all the tune i need. Took awhile but cel from dp did come on. Mhd is nice id recommend it if your ok with flashing your own ecu. If not, jb4 is good option especially if you dont do FBO.
As previously mentioned perhaps the jb4 ewg plug might need some cleaning or something. I will sell the jb4 & run just the mhd. I dont want to tinker, just drive. I like the mhd is out of sight & out of mind also. |
12-19-2018, 03:25 PM | #22 |
3441
Rep 79,211
