09-26-2018, 02:07 PM | #1 |
Rep 5,369
Do Dinan springs reduce the rear end pogoing?
My biggest gripe about the OEM M235 springs is the pogoing effect the rear end has over larger/ expansive bumps. The front end feels fine, but the rear has a lot of movement under these situations. Do the 30% stiffer Dinan springs help control movement?
09-26-2018, 08:41 PM | #3 |
Newer 2er
296
Rep 474
Drives: 2017 M240i (Sold)
I concur. The linear spring rate on the Dinan springs eliminates the float of the stock suspension. You also get way less body roll and less compression under acceleration. Made a huge difference in the car.
2017 BMW M240i (Sold)
2021 F-150 Raptor 2017 Porsche 718 Cayman S 2017 Audi Q5 |
bryan_G011164.50 |
09-27-2018, 02:16 PM | #4 |
Rep 5,369
Thank you. Are either of you running the Dinan spring spacers to bring the drop up a bit?
09-27-2018, 06:33 PM | #5 |
Rep 112
I am not. Just running the springs and Dinan bumpstops. Personally, I don't feel the drop is too low, but I am also running stock wheels and tires (for now).
DBinOC |
09-28-2018, 09:12 PM | #6 |
Newer 2er
296
Rep 474
Just bump stops as well. Running MPS4S 235s on 18x8 wheels with no rubbing or issues.
09-30-2018, 12:49 PM | #7 |
Rep 1,931
adjust the rear camber bolts to -2, this will help somewhat. it costs nothing.
www.nybmwcca.org
10-03-2018, 02:19 PM | #8 |
Rep 5,369
I must be dumb. How does adjusting camber reduce the rear pogo effect?
10-07-2018, 04:10 PM | #9 |
Rep 1,931
will help with overall handling. Just throwing it out there.
www.nybmwcca.org
10-31-2018, 09:49 AM | #12 |
Rep 3,496
Yes, did that take care of the pogoing effect for you?
trilax5991.50 |
12-21-2018, 01:51 AM | #13 | |
Rep 105
I'd like to stiffen-up the suspension but I don't really want it lowered. Thanks - Ken
2015 M235i 6MT | Alpine White/Black Dakota | MPerformance Body Kit | 19" M-Sport 359s w/Pilot Sport 4S (r:255/30 f:225/35)
BMS JB4 w/Bluetooth| Wagner Competition IC | Wagner DP | Evolution Raceworks IC Pipes | Dynan CAI | BMS Catch-Can | Active Autowerks Axle-Back | ECS 2-Piece Rotors/Hawk HPS 5.0 Pads | Full MP Carbon/Alcantara Trim | M-Performance Alcantara/LED Steering Wheel |
01-01-2019, 10:42 AM | #14 |
Rep 176
question
01-01-2019, 11:17 AM | #15 |
3626
Rep 3,592
The inner lower control arm and inner track link ends have eccentric bolts and washers that can be rotated to change the camber and toe in the rear.
