2Addicts | BMW 2-Series forum Technical Topics N20 (228i) / B46 (230i) Engine, Transmission, Exhaust, Tuning Exhaust Valve Rattle
      09-05-2018, 08:59 AM   #1
Blucar1
@nycarguy
Blucar1's Avatar
Drives: '14 228i M-Spt 18' X2
So I just had to replace the "Fixing Bow" connecting the Exhaust valve to the actuator controlling it. Figured I'd make a video on how to do it, in case you run into the same rattling issue. Really simple fix in my opinion.
https://youtu.be/tjudKpmO5zI
overcoil3073.50
      09-05-2018, 10:07 AM   #2
hwntime
hwntime's Avatar
270
Drives: F22 Raptor
Well made video. Was dropping the hangers necessary? And you also could use a jack stand to hold the muffler up in place when putting it back up.
      09-08-2018, 02:49 AM   #3
lazyleung
Drives: 228i THP 6MT
Thanks for the video! Helped me diagnose the problem immediately.
      09-08-2018, 06:44 AM   #4
overcoil
Drives: M235i 6spd
I watched the video the other day, it took me a day to realize how good the video was - at first I thought the video was too much shtick, but it actually was a very good instructional video, it kind of cleverly burnt the instructions into my brain.
      09-10-2018, 09:39 PM   #5
Blucar1
@nycarguy
Blucar1's Avatar
It's not necessary, but it makes things 1000x easier. One of the bolts is tucked away pretty well. Jack stand for the muffler is a good idea.
      09-10-2018, 09:40 PM   #6
Blucar1
@nycarguy
Blucar1's Avatar
Thanks, hope it helped!
      09-18-2018, 02:24 PM   #7
CapitaineBeaver
CapitaineBeaver's Avatar
Drives: 230i xDrive
My 230i is newer but developped this issue too. For now it's intermittent (it loves doing that when at car meets) and it stops when the JB4 opens the valve. I'll have my dealer look at it on the next oil change but I'm thinking about just unplugging it to leave it open and see if it would still rattle
'18 230i xDrive// Black Met // Coral Red // M-Sport // BM3 // BMS Intake // BMS OCC // Dinan Axleback // Daily Fun
      09-20-2018, 11:29 AM   #8
Blucar1
@nycarguy
Blucar1's Avatar
OF COURSE that's when it happens. Next the dealer "can't replicate the issue"
If you go that route, make sure you do when its in the open position. The rattle usually happens when its closed but still loose, so the exhaust gasses still push through, vibrating the valve.
      11-06-2018, 08:40 PM   #9
CapitaineBeaver
Drives: 230i xDrive
So I managed to fix the issue for good in a way. My car unfortunately was totaled in a front end accident with a drunk driver. For the new car I had installed a dinan freeflow exhaust that eliminates OEM valve. Problem : Fixed .. in a way like I said. I was about to get the dealer to fix my old one but faith killed the car.
      01-27-2020, 02:07 PM   #10
Storm2rooper
Drives: M235 Convertible
I agree! But then everything he takes about seemed like things I'd go through in the process of doing a simple "DIY" like wrong socket size lmao.
