07-01-2018, 10:34 AM | #1 |
Rep 160
Anyone running 225 F and 255 R RWD
How does it change the balance? More understeer? I'm getting a new set of rears and am considering options. Thanks!
07-04-2018, 03:02 PM | #2 |
Rep 1,369
I'm running 225/255. Obviously the more contact patch in the rear, compared to the front, the more car will understeer, but I don't notice a difference in daily driving. The increased grip off the line is noticeable though.
BM235iW97.00 |
07-04-2018, 10:54 PM | #3 |
Rep 160
Thanks for the info...I had figured that the tendency towards understeer shouldn`t be too noticeable in daily driving. Increase rear end grip will certainly be much appreciated .
07-05-2018, 08:41 AM | #4 |
Rep 503
What size wheels are you on, if you don't mind
07-05-2018, 12:31 PM | #5 |
Rep 1,369
18 x 8.5 and 18 x 9.5
MarkDemma519.00 |
07-06-2018, 07:59 AM | #6 |
Rep 1,931
225/40/18 and 255/35/18 rear re71.
They have same diameter and revs per min so these should be matched as a pair.
www.nybmwcca.org
07-20-2018, 10:34 PM | #7 |
Really Twisted
28
Rep 265
I'm running 18x8 all around with 225F/255R and they are great, understeer is minimal that I've noticed and straight/corners grip hold well
2021 Jeep Gladiator Rubicon
2015 BMW M235i F23 - Sold |
11-11-2018, 06:44 PM | #8 |
Rep 503
Hmm so it seems that you can run 225 / 255 on either 18 x 8.5 and 18 x 9.5 OR 18x8 on all 4. From reading, I realize that wheels will stretch one way or another to fit ... but just curious what the IDEAL size wheels would be if you wanted to run 225 / 255. Seems you have less options if you want to go with 18 inch wheels, but with the state of the roads where I live I'd be afraid to run 19s.
11-12-2018, 01:11 PM | #9 |
Rep 3,496
I would choose 8-8½ and 9-9½, respectively, going with the wider wheels if they would fit and if street and/or track performance was the application.
11-14-2018, 10:23 AM | #10 | |
Rep 823
MarkDemma519.00 |
11-23-2018, 07:50 AM | #11 |
Rep 8
Just speaking of tire section width and wheel width, without other considerations like aspect ratio, diameter, and offset, front 225 tire on 7.5" to 8" wheel and rear 245 or 255 tire on 9" wheel is great. My opinion after driving my new M240i for a few weeks is that it needs as much tire width on the rear as possible to put down the HP without wheelspin, and my own preference is to minimize the inherent understeer, so I like more rubber on the front. I settled on 245/40/18 tires front and rear. Wheel styles and offsets become a matter of personal taste also, but I think the limit on offset is about 30mm before tire to fender clearance becomes a problem.
12-14-2018, 12:54 AM | #13 |
Rep 2,601
18x8.5 et35 with 225/40
18x9 et52 with 255/35 Advan GTs and AD08R tyres. No noticeable increase in understeer on road or track. But I am running coilovers with camber plates and -3 camber front, -2 rear. |
aerodavew9.50 |
12-29-2018, 08:13 PM | #14 |
Rep 176
Do camber plates rattle and make a bunch of noise? I love the look of some negative camber but read some posts about noise. Any other risks/concerns getting them installed? Thanks for your insight!
12-30-2018, 02:46 AM | #15 |
Rep 2,601
No rattles or clunks, but there is more road noise transmitted to the cabin.
12-30-2018, 12:30 PM | #16 |
In search of the perfect cup of coffee
152
Rep 213
225 Front on 18 8.5 ET 35
255 Rear on 18 9.5 ET45 |
Funwithdesign35.50 griddle11.00 |
01-01-2019, 01:42 PM | #17 |
Rep 52
01-07-2019, 05:27 PM | #18 |
Rep 2,601
01-09-2019, 07:06 PM | #19 |
Rep 2,601
I chewed up my front tyres on track so now running 235/40/18 on the front.
02-15-2019, 02:45 AM | #21 |
152
Rep 213
I got mine from VMR on a Black Friday sale. That was the deciding factor, because as you said there are way too many choices out there.
02-22-2019, 09:10 AM | #22 | |
Rep 8
Its hip to be square!
Another trick is having the tires dismounted from the rims and flipping them so the former inside of the tire is now the outside. Some tire designs will allow this, some won't. Tread design and internal belt design are both considerations before flipping tires. But by using both tricks, the square tire setup and the flipping, you can greatly extend the useful life of your track tires. Talk to the folks at Turner racing if you think I'm off base here. Cheers Larry PS - I absolutely love that M140. BMW marketing won't bring those to the US though. |
Nugget649.50 |
