05-25-2018, 05:15 PM | #1 |
Rep 31
Street/Track Setup
I just recently got my car ready for track season this year. My car spends most of its time on the street, but it does see some HPDE action. I made the following changes this year:
PSS staggered to P4S square (245s on 8" wide wheels all around) Motul DOT 5.1 brake fluid Hawk street/race pads The setup feels really great on the street. The front end of the car feels much tighter (almost like the switch from comfort to sport mode). The pads have really good initial bite. They shrieked like nails on a chalkboard until they were bedded though! I ran Motul 600 in the past, but the shop that I worked with this time suggested that the DOT fluid would be best for street and track duties. I'm really happy with the setup so far. I think the biggest change is the new tires with the square setup. I thought I'd post this in case anyone is looking to do something similar. I haven't had it to a track yet this year, but I'll post impressions after I do. Happy motoring. |
05-26-2018, 11:28 AM | #2 |
Rep 2,873
I did almost the same to start into HPDE - pads and fluid, and new Conti's. I considered going to square, if I step up to new wheels - what are the specifics on your setup? any rubbing in front w/ the 245s, spacers?
05-27-2018, 10:03 AM | #4 |
Rep 31
I am not getting any rubbing at all. I am on the stock suspension with 18" Ultraleggeras. From what I've read here, it seems like 17" wheels might be the way to go, but I kind of made a concession to style by staying with 18s. I highly recommend the square setup.
05-27-2018, 06:24 PM | #6 |
Rep 1,541
The 5.1 fluid has a lower boiling point so it's considered more of a street fluid.
But I've ran RBF600 in all my cars and with the m2335i I've experienced inconsistent pedal feel with it at the limit. I've posted that I think it might have to do with the high viscosity of RBF600 not working well with the BMW brake system. I believe 5.1 is lower viscosity so it might actually be a better fluid for this car.
05-30-2018, 06:31 AM | #7 | |
Rep 2,357
M135i 8AT PWG, MHD, Pure Stage2, WMI via Torqbyte CM5-LT, Custom tuned by PureBoost
(A Dane in China) |
05-30-2018, 06:50 AM | #8 | |
Rep 281
05-30-2018, 07:13 AM | #9 | |
Rep 3,496
How did you code-out these brake assist features, which have no place on a race track? |
05-30-2018, 10:06 AM | #10 | |
Rep 1,541
I'll look into if I ever get back on the track with the BMW.
05-30-2018, 10:28 AM | #11 | |
Rep 3,496
Anthony235715.00 |
05-31-2018, 02:48 AM | #12 | |
Rep 2,601
I dislike the inconsistent pedal on track. |
05-31-2018, 11:10 AM | #13 | ||
Rep 1,541
05-31-2018, 02:33 PM | #14 | |
Rep 281
Yes, but, I am not sure you'll really want to do that. The stock system doesn't intervene too often, but when it did, I didn't like it. I wouldn't necessarily do it if I had stock brakes. I am going to keep the assisted coded off because I am ordering a BBK and won't really need the assists but they are actually not bad to have. As a matter of fact, I wish I had them this last weekend when I boiled my fluid and the pedal dropped to the floor. The assist would've provided some boost to give the car some stopping power whereas with everything coded out, I was on my own. This is an extreme example since my brake calipers did catch on fire several times due to over heating, destroyed seals, and possibly piston scoring. Needless to say, the stock brakes are more than adequate for tracking. But once you decide to track very often as I have, the front calipers simply aren't enough. Mine are black now...
Nugget649.50 |
05-31-2018, 02:46 PM | #15 |
Rep 2,873
I think this post has some info too, but I'm just going from what is left of my memory, and doing a quick search at work: http://www.2addicts.com/forums/showt...ghlight=assist
05-31-2018, 04:10 PM | #16 | |
Rep 3,496
I was very disappointed when the vehicle was totaled on the street by an errant driver, and the story came to an abrupt halt. |
06-01-2018, 10:55 AM | #17 |
Rep 1,541
When I had my EvoX we called them Brownbo instead of Brembo.
06-01-2018, 06:13 PM | #18 |
Rep 2,357
So what do you recommend to try instead of Motul RBF600?
My last session from Ningbo Racetrack (China) - hotlap @ 9:40
(A Dane in China) Last edited by harkes; 06-01-2018 at 06:29 PM.. |
06-01-2018, 07:53 PM | #19 |
Rep 2,214
Nice lap! I'm using Motul RBF 660, and it's great! No issues with pedal feel, if anything it's better than stock.
06-01-2018, 09:05 PM | #20 | |
Rep 2,357
RBF 600 Extreme high performance polyglycol brake fluid. Far exceeds the standards of DOT 4. Each bottle is filled with Nitrogen, increasing shelf life and eliminating contamination while factory sealed. Extremely high dry boiling point 594F(312C) helps prevent vapor lock and brake fade during hard use, with excellent recovery time. Wet boiling point 399F(204C). RBF 660 Very high dry boiling point of 622F (328C) and a wet boiling point of 399F (204C). For all types of hydraulic brake and clutch actuators requiring non-silicone synthetic fluid. Specially designed to resist extreme temperature generated by racing brakes (carbon and ceramic) only allowing a minimal air entrance for brake cooling.
(A Dane in China) |
06-02-2018, 11:58 AM | #21 | |
Rep 2,214
harkes1077.00 |
