03-09-2018, 04:39 PM | #1 |
Rep 65
Paint thickness on our cars...
I just purchased my car used, and unfortunately, a "detailer" left some slight holograms, probably with a rotary polisher... I'm pretty sure this will require a full cut and polish to repair, however, I'm a bit nervous because I'll need to do a fair bit of correction and don't own a paint thickness gauge.
From what I know, black German cars generally have a thick layer of paint/clearcoat - has anyone measured the paint on their black 2 series? Ever heard of anyone complaining of thin clearcoat on their cars? (if this sounds crazy, go to youtube and watch all the Ammo NYC videos) |
03-09-2018, 05:32 PM | #2 |
Rep 5,577
What kind of compound were you going to use?
Or were you going to use a light duty polish then finishing polish ? random orbital polisher ? If your were wet sanding or trying to eliminate orange peel then paint thickness will come into play. But if your using consumer grade ( which probably should be the first line of products to use) and random orbital then u won’t (shouldn’t) remove the complete layer of clearcost. Other things like polishes with fillers ( I wouldn’t use ) or wax strippers ( I would use ). You should first attempt to use the least aggressive sequence on a out of the way section first to see how the correction goes. If you have black paint and do a wash and dry with a mild correcting polish and random orbital and not transferring any paint to the pad then u know you have a good clear coat layer. |
03-09-2018, 07:20 PM | #3 | |
Rep 65
I'll first try removing the swirls with my lightest option (MF polish pad and finishing compound) and move up the compounds/pads if I need to.. it really should be fine, unless the someone tells me BMW paint is really soft, and the holograms are deep (I'll post pics in a few weeks, its still a bit too cold here to polish) |
03-09-2018, 07:38 PM | #4 |
Rep 5,577
03-09-2018, 08:52 PM | #5 | |
Rep 65
06-24-2018, 06:48 PM | #6 |
Rep 160
I'll be doing likely a full compound and polish on the car soon in preparation for ceramic coating...Not that I have a lot of detailing experience but I will share my experience assuming you haven't polished your car yet
07-01-2018, 11:44 PM | #7 |
Rep 160
Ok, finally got the car and got some compounding in...the paint is definitely not soft - at least not as soft as the paint on a Hyundai. I don't know how hard it is relative to the spectrum of other cars, but similar corrections take almost twice as long. But the Hyundai has super soft paint - it swirls if you just look at it wrong.
Using lake country yellow pad with Ultimate compound with a PC 74??. Works well - can't complain . Oh, and given that there was not one iota of wax on the car, the paint has help up pretty well. Paint prep is taking more time but at least I know it should be relatively resistant to future swirling etc... |
