2Addicts | BMW 2-Series forum Technical Topics DIY and Coding Discussions BimmerCode
      12-12-2018, 03:59 PM   #375
Hammy
Drives: 2019 BMW 440i xdrive
I got my Kiwi3 OBD device in the mail yesterday, just did some coding and it works great, might have been overkill on the device but figured it was better to be safe than sorry.
Here's the mods I completed:
  • Auto fold mirrors with comfort open / close
  • digital speedo (my favorite by far)
  • increased angel running light brightness to 40% (might go higher not sure)
  • audio shut off when door opens
  • door unlock with power off
That's it for now but this is unbelievably easy to use. The digital speedo alone was worth the price. There doesn't seem to be a built in code for showing engine temp, maybe it's in advanced? Can anyone assist with this?
      12-12-2018, 06:26 PM   #376
///M Houbi
///M Houbi's Avatar
Switzerland
1655
Drives: M2 Competition
I'm using the Veepeak OBDCheck BLE. It is faster and the connection is perfectly stable compared to vgate wifi which lost it a few times.
That's what I coded so far:
- Disabled shift point gear indicator
- Removed first fuel reserve warning
- Angel Eyes on 50%
- Radio off when door open
- Door handle LEDs on in reverse
- No horn while car locked and motor running
- Rain sensor sensitivity
- Rear vier camera zoom
- Seat heating to lower temperatures
- Start/Stop remembers last setting
- No A/C in Auto Mode
- Easy entry/exit
- Full text messages
- Additional Video Codecs
- Video via USB
- Some PDC related things
- Few more minor things
*EU cars have all the other cool stuff from factory like DRL, VLD, HBA, BFD, no nag screens and so on
      01-03-2019, 01:56 PM   #377
DasPanda
Drives: 2016 Alpine White 228i xdrive
Out of curiosity, does anyone know why it's cheaper on iOS vs Android?
Still, definitely worth every penny.
      01-03-2019, 07:07 PM   #378
Blucar1
@nycarguy
Blucar1's Avatar
Drives: '14 228i M-Spt 18' X2
Originally Posted by hwntime View Post
Per Bimmercode customer service, the 228i does not allow for this feature.
That's new then. I coded both on my '14 228i. Granted, I have the M-Sport package, but I don't think that would effect what graphics the ECU has available to use.
      01-04-2019, 02:44 PM   #379
kegobass
Drives: 2016 M235i xDrive
- Angel Eyes on 50%
- Easy entry/exit
- Video via USB
Did you need the Bimmerlink app to reset the error codes or is that not needed really?
Thanks!
      01-04-2019, 02:56 PM   #380
///M Houbi
///M Houbi's Avatar
Switzerland
1655
I did reset them after coding using Bimmerlink. But technically nothing bad would happen letting them in there..
      01-18-2019, 05:14 PM   #381
DasPanda
When rolling down your windows with the key fob, there's a delay. Is there a section where I can remove it?
I was able to code in where there's no delay for the windows to go up from the fob.
      01-23-2019, 12:30 AM   #382
danielduke
Colombia
Drives: ///M235i
Instrument cluster misreading
Hi everyone,
I did some codings to my f22, one of which I'm a little bit concern is that I enabled the digital speed indicator, but when I did that I noticed that the temperature that is displayed in the instrument cluster is crazy and also I did the coding whit a full fuel tank so now i'm getting a range fuel number very high and different as when I started coding.
Anyone can help me with this issue?
Thanks
      01-23-2019, 04:37 AM   #383
Clear_Blue22
Clear_Blue22's Avatar
124
Drives: 2018 230i MSport
2018 BMW 230i  [0.00]
Originally Posted by danielduke View Post
Hi everyone,
Thanks
It's been some time since I have been through the coding forums, but I'm pretty certain you are ok. I recall reading a bit about coding some things causing the temp to read way off and it will reset on its own. The fuel economy reading is the same way. When I picked my car up from Dinan after they installed a new mod for testing I saw I was getting insanely high gas mileage on the drive home. It's back to normal within one tank. If you're still having issues tomorrow reach out to Pikachu (?), he is really helpful to people in the coding forum.
      02-17-2019, 09:44 PM   #384
chmura
chmura's Avatar
1558
Drives: 2019 M2 Competition
- Angel Eyes on 50%
- Easy entry/exit
- Video via USB
What is - Easy entry/exit??
Also what PDC stuff did you change?
      02-18-2019, 05:45 AM   #385
///M Houbi
///M Houbi's Avatar
Switzerland
1655
Easy exit will make your seat move back a bit once you turn off the motor. Easy entry will move it forward a bit once you closed the door and pressed the start button. Makes the whol thing of getting in and out of the car a bit easier
Regarding PDC i changed the values for what speed PDC will be turned off. This allows my to exit the 4 floor garage in my office while having PDC on all the time. It's from the seventies so VERY tight all over...
Poochie9104.50
      02-18-2019, 01:42 PM   #386
Poochie
Luxury at the redline :)
Poochie's Avatar
Drives: 2016 M2
For those that want to try Easy Exit/Entrance. Works great if you're a fat ass..
In the SM2 (6d) Driver module:
3000 SM_GLOBAL -> EINAUSSTIEGSHILFE = Modus_FA_SLV
3012 EAH -> EAH_VERFAHRWEG_SLV_PHYS = Werte=00, 64
3012 EAH -> EAH_SCHUTZFREIRAUM_HINTEN_SLV_PHYS = Werte=00, 00
In the SM2 (6e) Passenger module:
3000 SM_GLOBAL -> EINAUSSTIEGSHILFE = UKNOWN, WERTE=03
The value equals = 64 (100mm). You could play with adjustments it to suit your need. I really don't know how to convert the value but you could lower it from 64 so it doesn't retract as far back.
      02-20-2019, 07:51 AM   #387
Climate Changer
Climate Changer's Avatar
2018 230i xdrive co ...  [0.00]
2019 x3  [0.00]
The value equals = 64 (100mm). You could play with adjustments it to suit your need. I really don't know how to convert the value but you could lower it from 64 so it doesn't go as far back.
This defiantly works. Check out this how to video in case anyone doesn't know how to use expert mode in Bimmercode
https://www.youtube.com/watch?v=UPOi5TqxmnM
KjPerry17.50
      02-21-2019, 06:06 PM   #388
H3G0N3_F22
H3G0N3_F22's Avatar
30
Drives: 2015 BMW M235xi
I have a M235i and for the life of me I can't get the mirrors to fold... Any suggestions??? I have all the comfort access and mirror settings Active with no delay...Thanks
      02-21-2019, 06:57 PM   #389
DistantTea
Drives: Oops
In bimmercode it was just selecting "fold mirrors with comfort closing". The timer didn't come into play for me. I like the standard delay. That option is found in front electronic module (FEM_01). If it's not in there it might not be a code for your car. 🤷🏻*♂️
      02-23-2019, 01:26 PM   #390
H3G0N3_F22
H3G0N3_F22's Avatar
30
Still did not work for me.Did your car come with comfort keyless access? From all the info I have obtained my car should have power mirrors and should fold... Thanks
      02-23-2019, 06:12 PM   #391
DistantTea
Drives: Oops
Yeah mine came with comfort access. I just activated everything in bimmercode that they didn't give us in the USA and it just worked.
      02-24-2019, 12:00 PM   #392
H3G0N3_F22
H3G0N3_F22's Avatar
30
Just opened up the mirror last night and found out that I do not have power folding mirrors, just power tilt. Thanks all for replying, time to see how to retrofit a set of power mirrors for a decent price. Reply if anyone has done this or know of a way to do it.
      03-20-2019, 05:44 PM   #393
TheNoOne
TheNoOne's Avatar
Drives: 228i Coupè MSport ZF8
Hello.
Coded some stuff already, but I'm struggling with something:
My car is from USA adapted for EU.
I have EU cluster and stuff and everything is perfect except for Cruise Control.
Once I turn the Cruise ON, on a digital display I see the speed in miles/h instead of km/h.
Same thing is in iDrive, setting up the Speed Alert, it's in miles/h.
Everything else is perfect. Digital speed is hm/h also.
Can someone help to solve this?
I tried to set the DEFAULT_WEG_EINHEIT --> km(0x00) but nothing changed.
In some forums I saw people solving this problem with this:
COC_V_EINHEIT
Wert_00 --> km/h
Wert_01 --> mls
COC_SETZ_V_MAX
Wert_01 --> km/h
Wert_02 --> mls
...but I'm not able to find those values with BimmerCode.
Please help...
      03-24-2019, 10:58 PM   #394
bmtespar
bmtespar's Avatar
Drives: 19 X3 30i, 18 230iX Vert
So I recently purchased a 2018 2 series with the large screen navigation running I Drive 6. I assumed I would have the ability to get text message notifications since every car I have had over the last 8 years has had the ability when you have the large screen system. I was shocked this car does not have the option and called Bmw and was told because the car does not have wireless charging, it also does not have ebt.
I tried coding some things in BimmerCode expert mode and got most thing functioning now like showing photo for contacts, two phones simultaneously connected, and I see the option in notifications pop ups for emails and texts but I still don’t get the option to “show notifications” in my Bluetooth setting on my iPhone nor do I actually get the notification in the car.
Does anybody have any suggestions on getting this working?
      03-25-2019, 12:22 AM   #395
Sisyrx
Budget Enthusiast
Sisyrx's Avatar
243
Drives: 2017 230i M-Sport
2017 BMW 230i  [0.00]
I tried coding some things in BimmerCode expert mode and got most thing functioning now like showing photo for contacts, two phones simultaneously connected, and I see the option in notifications pop ups for emails and texts but I still don't get the option to "show notifications" in my Bluetooth setting on my iPhone nor do I actually get the notification in the car.
I had the same issue until I realized I was coding for HU_NBT instead of HU_NBT_EVO like I should have been for my vehicle. Try this code (from user DMM2 in this thread: https://f30.bimmerpost.com/forums/sh...446&page=2)
HU_NBT_EVO > AUDIO_TUNER_TRAFFIC 3002 > AUDIO_OFFSET = aktiv
HU_NBT_EVO > AUDIO_TUNER_TRAFFIC 3002 > DAB_JOURNALINE = nicht_aktiv [Default]
HU_NBT_EVO > AUDIO_TUNER_TRAFFIC 3002 > MICROPHONE_NUMBER = wert_2
HU_NBT_EVO > EXBOX 3001 > USB_AVAILABLE = aktiv
HU_NBT_EVO > HMI 3000 > CDMM_AUX_SIMPLE_2 = nicht_aktiv
HU_NBT_EVO > HMI 3000 > CDMM_USB_COMPOSER_MSD = aktiv
HU_NBT_EVO > HMI 3000 > CDMM_USB_PORTS = usb1
HU_NBT_EVO > HMI 3000 > CDMM_USB_PORTS = usb1_sia
HU_NBT_EVO > HMI 3000 > OFFICE_MENUS_ACTIVE = aktiv
HU_NBT_EVO > SYSTEM_EINSTELLUNGEN 3004 > SOFTWARE_UPDATE_ASSISTANT = aktiv
HU_NBT_EVO > TELEFON_TELEMATIK_ONLINE 3003 > ADRESSBOOK = aktiv
HU_NBT_EVO > TELEFON_TELEMATIK_ONLINE 3003 > API_CAR_TYPE_IPOD_LOGO = bmw
HU_NBT_EVO > TELEFON_TELEMATIK_ONLINE 3003 > API_MP4_ON_OFF = aktiv
HU_NBT_EVO > TELEFON_TELEMATIK_ONLINE 3003 > API_MSD_EIN_AUS = aktiv
HU_NBT_EVO > TELEFON_TELEMATIK_ONLINE 3003 > API_USB_VIDEO = none [Default]
HU_NBT_EVO > TELEFON_TELEMATIK_ONLINE 3003 > AUDIO_NOTES_EIN_AUS = aktiv
HU_NBT_EVO > TELEFON_TELEMATIK_ONLINE 3003 > AUDIO_PLAYER_ON_OFF = aktiv
HU_NBT_EVO > TELEFON_TELEMATIK_ONLINE 3003 > BLUETOOTH_2ND_HFP = aktiv
HU_NBT_EVO > TELEFON_TELEMATIK_ONLINE 3003 > BT_MODUL_ON_OFF = aktiv
HU_NBT_EVO > TELEFON_TELEMATIK_ONLINE 3003 > CALENDAR_EIN_AUS = nicht_aktiv [Default]
HU_NBT_EVO > TELEFON_TELEMATIK_ONLINE 3003 > CE_DEVICE_SPEECH_RECOGNITION = aktiv
HU_NBT_EVO > TELEFON_TELEMATIK_ONLINE 3003 > CONTACT_BOOK_PICTURES = aktiv
HU_NBT_EVO > TELEFON_TELEMATIK_ONLINE 3003 > CONTACTS_EIN_AUS = aktiv
HU_NBT_EVO > TELEFON_TELEMATIK_ONLINE 3003 > EMAIL_EIN_AUS = aktiv
HU_NBT_EVO > TELEFON_TELEMATIK_ONLINE 3003 > ENT_BTAS_METADATA = aktiv
HU_NBT_EVO > TELEFON_TELEMATIK_ONLINE 3003 > MACRO_PIM = aktiv
HU_NBT_EVO > TELEFON_TELEMATIK_ONLINE 3003 > PHONE_CONFERENCE_CALL = aktiv
HU_NBT_EVO > TELEFON_TELEMATIK_ONLINE 3003 > PHONE_OBJPUSH_MENUE = nicht_aktiv [Default]
HU_NBT_EVO > TELEFON_TELEMATIK_ONLINE 3003 > PHONE_RESPONSE_HOLD = nicht_aktiv [Default]
HU_NBT_EVO > TELEFON_TELEMATIK_ONLINE 3003 > PHONE_TYPE = internal_phone
HU_NBT_EVO > TELEFON_TELEMATIK_ONLINE 3003 > PIM_BILDER_EIN_AUS = aktiv
HU_NBT_EVO > TELEFON_TELEMATIK_ONLINE 3003 > PIM_NEW_ELEMENT_AUDIO_NOTE = aktiv
HU_NBT_EVO > TELEFON_TELEMATIK_ONLINE 3003 > PIM_NEW_ELEMENT_EMAIL = nicht_aktiv [Default]
HU_NBT_EVO > TELEFON_TELEMATIK_ONLINE 3003 > PIM_NEW_ELEMENT_SMS = nicht_aktiv [Default]
HU_NBT_EVO > TELEFON_TELEMATIK_ONLINE 3003 > PIM_NEW_ELEMENT_VOICE_EMAIL = aktiv
HU_NBT_EVO > TELEFON_TELEMATIK_ONLINE 3003 > REMINDER_EIN_AUS = nicht_aktiv [Default]
HU_NBT_EVO > TELEFON_TELEMATIK_ONLINE 3003 > SINGLE_OR_MULTILINK = multilink
HU_NBT_EVO > TELEFON_TELEMATIK_ONLINE 3003 > SMS_EIN_AUS = aktiv
HU_NBT_EVO > TELEFON_TELEMATIK_ONLINE 3003 > SWUP_SOURCE_USBMSCDD = aktiv
HU_NBT_EVO > TELEFON_TELEMATIK_ONLINE 3003 > TASK_EIN_AUS = nicht_aktiv [Default]
HU_NBT_EVO > TELEFON_TELEMATIK_ONLINE 3003 > TEXT_NOTES_EIN_AUS = nicht_aktiv [Default]
HU_NBT_EVO > TELEFON_TELEMATIK_ONLINE 3003 > TWO_PHONES_PARALLEL = aktiv
HU_NBT_EVO > TELEFON_TELEMATIK_ONLINE 3003 > WLAN_DIAGNOSE = nicht_aktiv [Default]
2017 230i // Estoril Blue II // M-Sport
      03-25-2019, 09:22 AM   #396
bmtespar
bmtespar's Avatar
Originally Posted by Sisyrx View Post
I had the same issue until I realized I was coding for HU_NBT instead of HU_NBT_EVO like I should have been for my vehicle. Try this code (from user DMM2 in this thread: https://f30.bimmerpost.com/forums/sh...1439446&page=2)
This worked! However, my voice button on the steering g wheel is no longer functioning. I can still long press and get Siri but no in car voice control. Any suggestions?
