2Addicts | BMW 2-Series forum Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics Command Button Question for Owners
      03-30-2014, 06:15 PM   #1
BEM-S4
BEM-S4's Avatar
Hey, guys. Can someone please measure the top of the command controller button joystick whatever the damn thing is called? If memory serves there's a flat section before it starts to taper, just looking for the diameter of the flat top section. Want to get a decal made to go there. Thanks in advance, appreciate the help.
      04-01-2014, 10:20 PM   #2
ScottMZ3
Drives: 2018 Camaro ZL1, 2019 X5 40i
If you have navigation the top of the controller is a touch pad...a decal would probably cause that to no longer function. The nav controller is also larger in diameter than the non-nav one. If no nav installed you should be good!
- Scott
Current Cars: 2019 X5 xDrive40i M-Sport, 2018 Camaro ZL1
Past BMWs: '16 528i, '00 M-Coupe, '14 X1 sDrive28i, '00 740iL, '02 325i, '99 M-Coupe, '00 323Ci, '79 323i, '83 320i
      04-01-2014, 10:25 PM   #3
BEM-S4
BEM-S4's Avatar
Thanks for the heads up. Non-nav so it should be OK just need to figure out size.
