2Addicts | BMW 2-Series forum Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics BimmerTech Mirroring Unit Installation and Review
      06-16-2015, 09:27 PM   #45
WinterIsComing
Drives: M235 Convertible
2015 M235i  [0.00]
Originally Posted by Nelson@BimmerTech View Post
I'm installing one tomorrow afternoon. I'll post a demo.
Awesome thanks! Car gets into port this weekend *knocks on wood* and this may be the first mod. Looks pretty sweet.
      06-18-2015, 03:56 PM   #46
F48_Driver
Drives: BMW X1
No it wont. This unit only works on cars without nav.
Looking forward to it!
Thanks!
      06-22-2015, 07:37 PM   #47
WinterIsComing
2015 M235i  [0.00]
Nelson - how did the install go, hope you got a chance to capture a demo vid
      06-23-2015, 03:07 PM   #48
Ouzzo
Ouzzo's Avatar
52
Drives: F30 328i
How to connect audio so airplay works both audio and video
Awesome write up. Thanks a lot. Will definitely help as I attempt installing in my F30 tomorrow.
One question though I couldn't get the answer to from the videos.
How did you connect the audio so that you can both wireless airplay video and audio from the iPhone?
      06-23-2015, 08:36 PM   #49
configt
configt's Avatar
150
Drives: 2015 EB M235i
On one of the main harnesses that come with the bimmertech unit there is an AUDIO-IN cable. It is yellow. This is where you connect the audio out from the wireless airplay unit to. You can see it in my video when I am showing all the components.
      06-24-2015, 07:45 AM   #50
Ouzzo
Ouzzo's Avatar
52
Drives: F30 328i
thanks ConfigT , I guessed so but I saw some confusing posts that you would need to Connect the Wifi Box via a Hidden cable to the AUX in that is in the arm rest.
I believe connecting the Audio in from the Bimmertech Harness to the Wireless Airplay unit is much more elegant solution.
      06-29-2015, 06:34 PM   #51
washere
Drives: 2013 E93
So I am a bit confused on the audio out here too... I have the Bimmer-tech unit rearview camera unit (same as you are using here). But I am using a different source though.
I have connected my source to input 2 (both video and L/R audio). I am able to get video without a problem on the screen, but I get no audio through the radio. If I connect the L/R audio OUTPUT (the set you describe as having 2 yellow connectors) from the bimmer-tech unit to the aux in (in the armrest), it works fine. I assume I am just doing something wrong here? I am kinda unclear where exactly you think I should put the audio cables?
      06-29-2015, 10:32 PM   #52
configt
configt's Avatar
150
I am out of town now. When I get back I will take a look at mine again and get more details for you.
      06-30-2015, 07:33 AM   #53
WinterIsComing
2015 M235i  [0.00]
Could you walk through the process of getting into the mirroring? I'm trying to understand how complex/time consuming it is to go from starting the car up to mirroring your phone.
Once its being mirrored it looks amazing, but none of the online demos show actually getting into the mirrored mode, they all pick up after its already there.
      06-30-2015, 10:24 AM   #54
washere
Drives: 2013 E93
One question. To hear audio from the mircacast, do you use the AUX input for the radio to get the audio into the radio, or is it being fed directly into the radio from the Bimmer-tech unit into the radio?
      06-30-2015, 10:32 AM   #55
e46m3to335i
e46m3to335i's Avatar
Drives: 2015 F80 M3
I would like to see this process as well.
      07-01-2015, 05:52 AM   #56
configt
configt's Avatar
150
Sure I will do this for you sometime this week when I get back from work.
      07-02-2015, 10:43 AM   #57
WinterIsComing
2015 M235i  [0.00]
Thank you!
      07-09-2015, 09:08 PM   #58
WinterIsComing
2015 M235i  [0.00]
Were you able to get a chance to put that together? Thanks again.
      07-09-2015, 10:22 PM   #59
configt
configt's Avatar
150
Hey man! Sorry, I have been so busy with work I didn't get around to it. Give me an hour and I will get it uploaded for you!
Thanks
      07-09-2015, 10:54 PM   #60
configt
configt's Avatar
150
Here you go:
      07-09-2015, 11:03 PM   #61
configt
configt's Avatar
150
Ok, so from the BimmerTech Mirroring unit, you have 3 outputs: Video, L Audio and R Audio. You need to connect the L and R Audio to the "Audio Input L&R" on the main power harness going to the BimmerTech unit. Then when you are using the mirroring unit, go to the AUX IN input selection iDrive. This is not the same AUX IN as the one in the arm rest area. Here are pictures from my video showing what I am talking about:
      07-09-2015, 11:53 PM   #62
e46m3to335i
Drives: 2015 F80 M3
Here you go:
Thanks a ton configt!!!
      07-10-2015, 12:26 AM   #63
configt
configt's Avatar
150
Anytime
      07-10-2015, 07:18 AM   #64
WinterIsComing
2015 M235i  [0.00]
Thanks
No worries - figured you got caught up based on your last message and wanted to just drop a reminder. Thank you so much for all the help, this is great!
      07-10-2015, 07:21 AM   #65
WinterIsComing
2015 M235i  [0.00]
Here you go:
Very very cool... I think its sold me!
      07-10-2015, 06:32 PM   #66
F48_Driver
Drives: BMW X1
20% off this weekend!
Coupon Code: Smartview20
