2Addicts | BMW 2-Series forum Technical Topics Mechanical Maintenance and TSBs: Break-in | Oil & Fluids | Servicing | TSB Power Steering Fluid / b46 / 20' 230
      07-24-2021, 01:01 PM   #1
nazali
nazali's Avatar
Drives: 230 2020 vert F23
Hey Guy's
so I got under the hood to just do a check on the fluids.
I found the power steering fluid, but it's inches away from what looks like a strut, and the coolant (see pic).
I tried to release the cap but it was jammed tight, even trying to turn from left to right. I can only get my finger tips around the cab, I'm hesitant to use any force or tools.
Am I missing something, I might need a big wrench, as it's band new I suspect it's never been opened
txs
      07-24-2021, 01:12 PM   #2
nazali
nazali's Avatar
this is a better view (not my pic, just off the net)
      07-24-2021, 02:12 PM   #3
jzeiler4
jzeiler4's Avatar
Drives: 2021 M240i xDrive vert
That is the cooling system's expansion tank. The steering is electric, no fluid no pump.
      07-24-2021, 02:55 PM   #4
nazali
nazali's Avatar
oh... 2 expansion tanks ? Top one is ? so is bottom one ? Do I need to check or do anything with that ?
      07-24-2021, 02:58 PM   #5
nazali
nazali's Avatar
ok got it
https://www.newtis.info/tisv2/a/en/f...rts/1VnYny3XMZ
high temp and low temp circuits
wow
      07-24-2021, 05:23 PM   #6
aerobod
aerobod's Avatar
3630
The intercooler coolant cap should unscrew easily when the coolant is cool, but it does have a locking “notch” that you initially have to overcome, which may make it feel tighter than it actually is.
nazali1313.50
      07-24-2021, 06:41 PM   #7
nazali
nazali's Avatar
txs, no the engine was stone cold
I just couldn't only get my finger tips on it, without removing stuff
and just wouldnt budge, "UNLESS" anyone thinks I need to open it to check
I'll leave as is
