2Addicts | BMW 2-Series forum Technical Topics Mechanical Maintenance and TSBs: Break-in | Oil & Fluids | Servicing | TSB How to lift car for an oil change
      01-21-2017, 02:12 PM   #1
peterdf
Drives: 2016 M235i Coupe
2016 BMW M235i  [10.00]
I want to perform oil changes myself between the warranty-covered oil changes, and I'm having trouble figuring out how to lift it. I've read that the car needs to be level in order to drain oil properly, but I'm not sure how I can do that without 4 ramps. My garage also has a slight grading towards the garage door, so even then I'm not sure I can lift it evenly. Without ramps, would it be possible to just jack up the front of the car and do the oil change that way? Otherwise, I have no idea how I'd life the car evenly with the jack, unless I leave one rear corner with the jack, and the other 3 corners with jack stands.
BMW CCA Member# {512318}
      01-21-2017, 02:32 PM   #2
123Britt
Drives: 15 M235i AT
Ramps for OIL CHANGE
The RhinoGear 11909 RhinoRamps Vehicle Ramp
      01-21-2017, 03:39 PM   #3
overcoil
Drives: M235i 6spd
I use a Arcan 3-ton jack (with ReverseLogic jack pad tool) to lift front drivers side (lift about 8 inches) and double chuck diagonal wheel.
Then I place an appropriate short jack stand under suspension inner lower attachment to body and a wood block under center frame lift point.
Then with a shallow drain pan situated appropriately I get under to flip open drai door and loosen drain pan bolt.
Once oil flows, I remove center wood block and jack stand, then carefully lower floor jack to make car almost level without cracking drain pan. Wait till it drains, jack back up and reinstall wood block and jack stand, replace drain plug gasket and plug, tighten bolt to spec, and thankfull car didn't drop while I was underneath.
      01-22-2017, 06:20 PM   #4
Solarphil
Drives: Nickole - MG & CR M235i
Level is a relative term re oil changes - you don't need to get a perfect "make the noise" kind of level, just good enough to drain. A pair of ramps are a good safe easy way for diy oil changes, you don't need all four wheels in the air.
I wouldn't want to be under a car that's on a jack.
      01-23-2017, 07:05 AM   #5
EuroDude
Drives: 2017 GT350
2017 Ford GT350  [0.00]
I'll second what 123Britt said on the Rhino Ramps.
      01-23-2017, 07:44 AM   #6
overcoil
Drives: M235i 6spd
Which model Rhino Ramps won't run against bottom off 235 front air dams and underbody tabs ?
      01-23-2017, 10:51 AM   #7
mdputnam
mdputnam's Avatar
289
Thinking about the many thousands of times I've jacked up a car and the many thousands of more times I'm going to, I finally decided to quit wasting time with jacks and ramps. So, I treated my self to a QuickJack. Yea, it's pricey at $999 but, it saves so much time and head ache it is worth it. There are many manufacturers of these portable jacks out there, I bought the BL-3500SLX Car Lift because it is compact relatively light and has a very low profile (Hey, there are no SUVs in this household ). Best part you can hang the whole system up on the garage wall when you're not using it.
      01-23-2017, 10:35 PM   #8
EuroDude
Drives: 2017 GT350
It is a close fit, if you're talking about the flexible rubber tabs, no biggie as they can handle flexing. All I do is run some painters tape on my white front lip edge, no big deal at all. If your car is lowered or you have a splitter, you will have problems.
      01-24-2017, 01:52 PM   #9
delvec03
Drives: 228i Sport/ DSB
eek...3,500 lb capacity? Cutting it close no?
      01-25-2017, 11:14 AM   #10
mdputnam
mdputnam's Avatar
289
Cutting it close yes! Actually a little over, my convertible is 3692lbs.
      02-09-2017, 06:39 PM   #11
idontkickpuppies
Drives: 240i on order
Have you consider using a Topsider or something similar? The one time I used one it worked flawlessly.
If everything seems under control, you're not going fast enough.
- Mario Andretti
1FUNCAR20.50
      02-13-2017, 05:33 PM   #12
SteveInfante
NewFinishColumbia/detailer
SteveInfante's Avatar
Drives: 2015 F31 xDrive
Don't forget to figure out if you have the plastic oil pan or the metal one. I bought a magnetic 17mm drain plug as I always do and when I got the 228 up and went under I had the plastic 10mm hex plug and the plastic oil pan. Apparently the metal one uses the 17mm plug.
78' Honda CB400A project
      02-16-2017, 01:04 PM   #13
EuroDude
Drives: 2017 GT350
Plastic 10mm hex for the oil drain????? Doesn't sound right to me
      02-17-2017, 04:54 AM   #14
SteveInfante
https://www.ecstuning.com/b-genuine-...t/11427640862/
Plastic drain plug. 10mm Hex.
      02-20-2017, 01:32 PM   #15
Tpeterson
Tpeterson's Avatar
Drives: 228i MSport/THP/MT/
It's on the RWD 228i.A new plug comes with the oil filter and it is self torquing to spec,8 Newton meters,I think. The 228Xi and, I assume, the M235i have steel pans. It was unnerving to see such a fragile looking plug coming out of the pan, and such low tightening torque, but the new one went in fine ,no leaks,no loosening.
      02-20-2017, 08:11 PM   #16
SteveInfante
I just did my oil change today after getting a 10mm hex socket. Went in no fuss.
      02-24-2017, 03:12 PM   #17
Viffermike
Viffermike's Avatar
If only the car on it could be had for 10 times that much, like they were 5-6 years ago ...
--Helmets are for closers.--
      04-14-2018, 11:15 AM   #18
1FUNCAR
1FUNCAR's Avatar
Drives: 2018 M240i Coupe
I've actually been wondering the same thing.
      04-14-2018, 11:34 AM   #19
aerobod
aerobod's Avatar
3626
There isn't a dipstick for the oil, so it is virtually impossible to use a vacuum oil extractor.
      04-14-2018, 10:19 PM   #20
delvec03
front, cener jack point.
rear, rear diff.
      04-30-2018, 02:12 PM   #21
biz4two
Drives: 2014 f22 n20 228i
Arrow
That is a GREAT tip!!
I use the 10mm hex plug on my setup...and it works fine!! It's totally strange to only torque to 8Nm!!
biz
2014 BMW 228i f22 n20
Prod.date: 2014-06-27
      04-30-2018, 02:23 PM   #22
biz4two
Arrow
With such low stance, I had to use the two floor jack approach.
1. 2 ton jack lift at front driver side lifting point
2. with BMW in the air about 6 or 8 inches, then used 3 ton jack at front center lifting point
3. Jack BMW up enough to place ramps under each front tire
4. Lowered BMW onto ramps and removed 3 ton jack
Performed oil change, per normal process. Then reverse the lifting procedure above.
NOT terribly difficult, but more of a process than other vehicles I've owned...and performed oil changes on.
Definitely will be purchasing a high quality low profile Alum floor jack!!
biz
