07-20-2020, 07:15 PM | #1 |
Rep 864
BM3 M2 Stage 0+ vs Stage 1 93
Started with VRSF CP and 5" HD FMIC
. Added BM3 Today: My plan was to run the highly touted Stage 0+ M2 tune. I set up my battery charger and let it charge until it was about 70% charged. Set my Mac preferences to turn off the Firewall and loaded the Agent. Selected the OTS Maps and downloaded the M2 Stage 0+ map. Went to My Maps and saw the new map there and started the Flash. Took about 5 min and then it showed 98% Complete and it just froze up. After 10min I went back and ReFlashed the M2 tune again and this time it Completed. I waited 10 seconds and started the car. Went for a drive and it was faster at least somewhat noticeable but to be honest I was very disappointed. My M235i was quick in stock form and now it was a little quicker but NO real WOW! factor. I had planed to stick with this M2 Tune as my Top End Tune. After a 15 min drive I knew what I had to do. I drove back to my house and pulled in the driveway close enough to gain Wi-FI access. Plugged in the OBII and Flashed the Stage I 93 Octane. Only took like 90 seconds -- Really quick flash time. As I pulled out of my neighborhood --- an about 5 min down the road I was like --WOW!!!! So SMOOTH, SO FAST & The Torque!! The gauges were updated in Stage 1 ( where Stage 0+ they were at a 400 hp /tq limited) and now in Stage 1 480/560 Gauge Limits. The car will push you back in the seat and the car feels so complete. You would never know that this was not an OEM Tune. I highly recommend this BM3 Tune (purchased from x-hp.com -- Thanks Mike!) Really think this tune is simply amazing & pure --- VERY DIRECT AND LINEAR. I just can't say it enough -- Tune that N55 today!!! I look forward to checking out my logs & will share as I learn how the tune is running on my car. Cheers! |
07-21-2020, 07:06 AM | #2 |
Rep 87
Congrats! I'm currently running the same tune as you and am happy with the noticeable improvements. Will probably go FBO and Stage 2 next year (I drove stock for 3 years while on warranty so there is no rush LOL), but for now like you say it's a lot better!
Chris |
07-21-2020, 08:28 AM | #4 |
Rep 864
Tune Transmission or NOT
With only Stage 1 and the M235i ZF8 already being very accurate and quick -- I am debating if I should Flash the BM3 ZF8
. . Anyone have Experience with this BM3 Transmission Flash?? |
07-21-2020, 08:38 AM | #5 | |
Rep 864
Superior M2 Stage 0+
the Stage 1 93 low end torque for my DD suits my driving and provides that FUN Factor. Not many places to DD (80-130mph). Its not how fast you drive but how much fun you have getting there. . . I could barely tell the difference between Stage 0+ and Stock M235i except above 5k where I am not able to spend a lot of time. |
AmuroRay2267.50 |
07-21-2020, 11:47 AM | #6 |
Rep 190,725
Thank you for sharing
07-23-2020, 05:53 AM | #7 | |
Rep 130
For me that is key too. Which is why I drive manual, changed the final drive ratio and focus on letting the fantastic engine rip up to high rpms
[FONT="Arial"] M235i 6 speed, MGM. Wavetrac LSD with altered final drive ratio, MPE, MPK Airbox, side skirts, diffuser, Dinan springs, LCAs.
07-23-2020, 09:00 AM | #8 |
Rep 314
You definitely want to do the TCU flash stage 1 or 2 it's lifts Torque limits in 3 and 6 gear, increase clamping force, a little faster shifts. If you want to go a little crazy with the TCU try XHP flash 👍🏻
Kiel McCaul
07-23-2020, 12:08 PM | #9 | |
Rep 864
M235i 550nm in all Gears
3rd and 6th NOT reduced in M235i. Yes - I am going to Flash the BM3 ZF8 Tune and compare . |
07-25-2020, 09:51 PM | #10 |
Rep 4,132
For everyone else -
https://f87.bimmerpost.com/forums/sh....php?t=1610213 https://f30.bimmerpost.com/forums/sh....php?t=1616837 Op may like the BM3 tune because of his driving style - some people like torque |
Heitzer103.00 |
07-27-2020, 10:38 PM | #11 |
Rep 38
Thanks for sharing OP! Do you have any logs you could post? I'm experimenting with both tunes as well and settled on the stage 0+ M2 tune (for now). Would love to compare logs.
10-31-2020, 04:02 PM | #12 |
Rep 864
Stage 0+ -- Not the Torque Monster of Stage 1
The Stage 1 93 Octane on my M235i -- can spin MP4S tires so easily being there is a load of low end torque. Which makes it soooo much fun to drive.
However, with winter on the way -- I recently flashed back to Stage 0+. WOW! What a difference. More Top end HP but less wheel spin. I completed a datalog and found my Costco 93 did just fine. Timing was very consistent across cylinders with NO knocks. Target Boost was mostly in the 15.0 range but did have one peak at 17.4. I will keep it on Stage 0+ until next Spring and then switch back to the Torque Monster. Happy Halloween! |
Heitzer103.00 |
05-20-2021, 02:05 PM | #14 |
Rep 864
My Setup - BM3 Stage 1 93
With my Wagner Catted DP, VRSF 5" IC & Charge Pipe & Now adding FTP Turbo inlet .
Stage 0 : Feels quick above 5000 RPM with less wheel spin off the line as compared to Stage 1. Stage 1 : More Sound and much more wheel spin off the line. Definitely catching wheel spin at lower speeds. Feels more fun to drive. I bet 0-100 mph would be faster in Stage 0 due to less wheel spin off the line. However at a 30mph rolling start -- Stage 1. Gage Cluster on dash HP / Torque limit is adjusted BOTH : Feel OEM quality smoothness -- just faster. I do not dare go to Stage 2 -- I could never go back. |
05-23-2021, 11:37 AM | #15 | |
Rep 116
2015 Estoril Blue 6-Speed M235i
Heitzer103.00 |
05-23-2021, 11:41 AM | #16 |
Rep 116
[IMG]undefined[/IMG]
So very small changes. Trash times, not trying to beat up the clutch too much, but car is consistent with it's traps.
05-24-2021, 06:29 AM | #17 | |
Rep 130
I am running an LSD with the final drive ratio changed from 3.08 to 3.46 in my M235i. The M2 map fits perfectly with the character of the car. The final drive ratio of the original M2 was also 3.46 for 6 MT, btw. With the change I can fully experience and hear the engine closer to legal speed limits In terms of linearity it feels almost naturally aspirated. Can only recommend to give it a try.
Polo088161610.00 |
05-24-2021, 08:14 AM | #18 | |
Rep 3,946
06-04-2021, 02:11 PM | #19 |
Rep 90
Drives: 2020 X5; 2016 M235i Conv. 6MT
Can you get to either the M2 or Stage 1 flash with everything stock?
06-05-2021, 08:54 AM | #20 |
Rep 190,725
You can
