06-21-2020, 06:33 PM | #1 |
Rep 439
Drives: 2016 M235i Xdrive 8A
BM3 E30 vs Cary Jordan 93 AKI
Which would net higher peak power output?
Wondering if its worth the $550 for his refinements on my map or if the OTS E30 map would do it for $50...
2016 F22 M235 8A HK NBTevo | CTS HEX Intake | CTS Chargepipe | Gplus Intercooler | VRSF DP | BM3 Stage 2+ | 18" CSL Replicas | XHP X-Delete |
06-22-2020, 10:20 AM | #2 |
Rep 190,750
100% worth it in my opinion.
I went from E30 OTS map to 100% E85 Jordan map on my M4 and the difference was night and day
07-30-2020, 05:32 PM | #5 |
@_sunbish
282
Rep 611
Yes sir. Camera car is full weight 435i (which already is heavier than a 335i similarly equipped) was on a stock air box and completely stock exhaust besides downpipe. 335i had rear seats removed, aftermarket CAI I believe Injen (which adds power no matter what anyone says), and resonator delete which may not may not add power but it does further remove weight. Custom tune or not, I don’t believe straight 93oct will make more power or be quicker than E30 OTS tune.
The custom tunes NEED meth and 93 or higher ethanol content to make a difference. |
07-31-2020, 10:09 AM | #6 | |
Rep 4,134
https://x3.xbimmers.com/forums/showthread.php?t=1425837 But you two should do a proper dyno or compare logs in virtual dyno.
Mods: Yes.
08-01-2020, 04:58 PM | #7 | |
@_sunbish
282
Rep 611
I'm not saying custom tunes don't make a difference, they just aren't worth the money on a straight 93oct tune. Now if someone is adding meth to a 93 or E30 tune (which cools the IATs and raising octane) or is going to a higher ethanol content than E30 provided they have the fueling (aftermarket HPFP), then the gains will definitely show. AmuroRay, I once posted some logs and you're more than welcome to put that on a virtual dyno. I have no clue as how to do that lol. I'm with you on the intake, maybe adds 5-10whp at most. I'm just posting all the differences that actually do add power or reduce weight to make a difference in the grand scheme of things. |
08-06-2020, 06:21 PM | #8 | |
Rep 124
Custom tuning makes the car feel that much more like factory(no strange hiccups) while giving you the extra kick.
IG @jq_f22
08-07-2020, 05:06 PM | #9 | |
Rep 439
08-07-2020, 05:09 PM | #10 | |
Rep 439
08-10-2020, 04:09 PM | #11 | |
Rep 4,134
08-13-2020, 05:48 PM | #12 |
@_sunbish
282
Rep 611
