2Addicts | BMW 2-Series forum Technical Topics N55 (M235i) Engine, Transmission, Exhaust, Tuning Grinding Noise Under Light Acceleration (Pulley?)
      05-04-2020, 04:18 PM   #1
Mullins
Drives: M235i EB
Hey all, who's up for another round of WTF is that noise?!
I've been hearing this sound for a while now, it's typically always noticeable when i pull into my garage, after the car is warmed up. I always notice it when I come to a stop, and put it in Park (I do that towards the end of the clip), but you can hear it as I begin to apply gas every time. When it sounds like it's chattering, thats me tryin to just hold it in the range where it makes the noise.
I want to say it something like an actuator, perhaps the throttle body? I can also hear it under acceleration while driving, but its harder to capture.
Adding a second video which it's much more repeatable. I was able to replicate the noise easily when in Drive and holding the brake pedal while lightly applying the gas. You can hear the sound every time, and when i let off the gas, it sounds like the actuator "resets" or something. I need to see if I can do this while my wife is in the car, and I have the hood open...
Any ideas?
Edit:
Well, after opening the hood and having my wife put it in drive and apply the gas (sounds super safe, right?), i think I may have the culprit. I think the belt tensioner might be making the noise? Aside from the noise, it seems pretty wobbly when under load? Ive seen a few replacement suggestion for wobble, but I've never seen a mention of a noise like this. Anyone seen/heard this before? Hard to tell for sure...
      05-13-2020, 10:30 PM   #2
GarrettM235i
Drives: 2015 BMW M235i
Experiencing a similar noise. Mine is much quieter. Just a slight metallic chirp/grind under mild throttle only. Just as I press the pedal and a similar but slightly different noise just as I let off. Hard to hear at high speeds but I hear it cruising through the neighborhood in third gear. Thinking it's possibly a sticky waste gate actuator. Not sure. Will keep up to date.
      05-14-2020, 08:00 AM   #3
BrandonMllr
Drives: BMW 1series F52
The sound really throttle.
      05-19-2020, 02:18 PM   #4
Mullins
Drives: M235i EB
Added a second video which I'm able to reliably repeat the noise.
      05-19-2020, 03:26 PM   #5
The_otherM235i
Driver - Autocross
The_otherM235i's Avatar
Drives: BMW M235i
Fan turning on maybe?
16 M235xi 8ZF Black on Red FBO: Xhp trans tune -BMS Intake - VRSF Catless DownPipe - VRSF CP - VRSF Muffler delete/resonator - n22 plugs - MHD stage 2+ 95map - Wagner EVO II Preformace IC - Rear seat delete - weight reduction/stripping -FTP 18.5in rims - Hawk HPS front pads - StopTech STR 660 fluid
      06-15-2020, 04:04 PM   #6
Mullins
Drives: M235i EB
Posted an update, I think it may be the belt tensioner, but its hard to say for sure. I only have 35k miles on the car, seems a bit early for something like this to go out?
      06-16-2020, 12:53 PM   #7
khj24
khj24's Avatar
221
Drives: 2015 m235i
Sounds like a bad pulley bearing to me
      07-13-2020, 05:17 PM   #8
Mullins
Drives: M235i EB
Well, I swapped the tensioner and the idler pulley with the kit from FCP and the noise appears to be gone. Neither of the wheels appeared to be grinding at all, and seemed in good health but hard to tell when not under pressure. Consider this solved...
