08-01-2019, 05:57 PM | #1 |
Rep 87
Stock-ish Dyno Sheet to be followed by more
Attached is the dyno sheet coming from a 2015 M235i with approximately 66,000KM (41,000 Miles).
5th gear pulls Max HP is 290 and max torque is 338. The car right now has no tune, only mods are an axle-back (Remus) and Active Autowerke charge pipe and intercooler, but without a tune (and in the case of the exhaust, even with) I’m sure those don’t add any significant power. In a few weeks I hope to post a sheet from the same car, with a Wagner downpipe and an intake, followed by the whole thing with bootmod3 OTS maps and maybe a custom tune. |
08-02-2019, 10:09 AM | #3 |
Rep 87
I don’t think so no? It was a super hot day, maybe I could’ve hit 295 in better conditions but on 91 octane, no tune, this is pretty much in line with what I’ve seen in the past. In any case, you can’t really compare different dynos so the goal is more to compare this baseline VS wagner catted + bootmod3 OTS and then bootmod3 custom tune.
08-02-2019, 10:39 AM | #4 |
Rep 190,633
Nice OP!
Low compared to what? this is his baseline which he will be using for comparison. You cant compare different dynos with different cars.
08-17-2019, 08:17 PM | #8 |
Rep 351
stock advertises 320 hp. bmw specs are usually low to begin with....I just expected more?
08-17-2019, 08:22 PM | #9 |
Rep 5,366
BMW rates the M235 at 320hp at the flywheel. Dynos measure power at the wheels. The M235s are underrated. They make closer to 360hp in stock form based on numerous dynos done over the years.
OldCrow7xx72.50 |
08-18-2019, 07:11 PM | #11 | |
Rep 351
08-19-2019, 12:20 AM | #12 |
Rep 5,366
Every brand of dyno measures power a bit differently. The way to calculate flywheel power from measured wheel power (a dyno), you take the wheel power and divide .85 to .83 to account for drivetrain loss as the flywheel power gets a bit consumed by spinning the transmission, the driveshaft, differential, axles, wheels, and rotors.
So take 290 and divide by .83 (assuming an auto) and you get 350hp at the flywheel. |
OldCrow7xx72.50 |
08-19-2019, 09:43 PM | #13 | |
Rep 190,633
Its used to compare delta between stock and once mods are installed
OldCrow7xx72.50 |
08-20-2019, 10:55 AM | #14 | |
Rep 5,366
They are not the best dynos for tuning as you can't vary load on the drum (i.e., Mustang dyno and the like), but when it comes to "the numbers" they are extremely consistent and within 2% to 3% of the same model car dynoed on a Dynojet in CA vs one dynoed on a Dynojet in NY assuming the same correction factor standards are used and the car is in a good state of tune and not super heat soaked. It's also nearly impossible to manipulate the data on a Dynojet. You could make wild changes to the correction factors but it would be very obvious that you're doing that. When it comes to companies showing power gains for mods, a Dynojet is the best tool for the job, IMO. For tuning, a load-based, brake style dyno is the only way to go.
OldCrow7xx72.50 |
08-20-2019, 05:38 PM | #15 | |
Rep 4,130
08-21-2019, 10:07 AM | #16 |
Rep 5,366
There are Eddy Current (load varying) Dynojets available now, but most are still the standard inertia style "X" (inertia) units as they are far cheaper and are what most people want.
The Eddy Current ones are really pricey and are typically used for custom tuning to emulate driving on hills, launching, cruise, light and heavy throttle tip-in, etc. Most people aren't willing to throw down $500+ for a tuning session on a load-based dyno. Load-based dynos are without the best dyno to gauge the state of your car's tuning strategy. An inertia dyno and most any other dyno plot you see posted on forums is simply a full throttle run in the 1:1 gear to measure max power. Nothing more. A Dynojet is ideal for that, IMO.
06-04-2020, 09:24 AM | #17 |
Rep 87
Just a quick update - didn't do any tuning last summer but did get ready for a stage 2 by adding a downpipes and BM3. As soon as my summer tires are on (pandemic delays hah) I am going to be getting a custom tune for this, which I will post about here.
Then once I got that custom tune and it's running well I'll try to get it dynoed on the same dyno. Thanks! |
06-08-2020, 09:46 AM | #19 |
Rep 4,130
All of these numbers are what you would expect from a M235i.
Stock around 290whp+/- It seems that a few bolt ons (with no tune) can add as much as 15-30whp and 30-50wtq.
Mods: Yes.
OldCrow7xx72.50 |
06-10-2020, 06:53 PM | #20 |
Driver - Autocross
74
Rep 178
What i'm most pissed about is the fact that a FBO M235i on perfect conditions can't even put down 400 wheel.
16 M235xi 8ZF Black on Red FBO: Xhp trans tune -BMS Intake - VRSF Catless DownPipe - VRSF CP - VRSF Muffler delete/resonator - n22 plugs - MHD stage 2+ 95map - Wagner EVO II Preformace IC - Rear seat delete - weight reduction/stripping -FTP 18.5in rims - Hawk HPS front pads - StopTech STR 660 fluid
OldCrow7xx72.50 |
06-11-2020, 06:51 AM | #21 |
Rep 87
06-11-2020, 04:05 PM | #22 | |
Rep 8
Stage 2 w/ E30, downpipe, intercooler, charge pipe. You can get close running 91 octane, though. https://www.2addicts.com/forums/show....php?t=1490691 Of course, I am not there...yet. When I get my parts, I hope to do a Stage 2 E30 dyno run to confirm. Last edited by RandomBMW; 06-11-2020 at 04:08 PM.. Reason: Spelling error |
Efftooto43.50 |
