THE ULTIMATE Intercooler Thread - What to Look For Before Buying an FMIC |
03-02-2016, 04:36 PM | #1 |
Rep 190,777
There has been numerous threads lately about intercoolers. From the usual which one is the best FMIC on the market to Ebay brands claiming to offer a high quality solution for a reasonable price.
I will be discussing the most important factors about intercoolers and why some FMIC will offer better cooling than others Intercoolers and why replacement is recommended? Turbochargers compress engine intake air which creates heat. The Intercooler then cools down the charged air. For remapped cars, temperatures up to 200°C after turbocharger can occur. Factory intercoolers are unable to sufficiently handle such high temperatures. This causes high intake temperatures and the oxygen content of the charged air drops significantly. As a direct consequence, the performance decreases, the thermal load on the cylinder head and valves increases. Worst case this can cause severe engine damage. The colder the intake air, the higher the efficiency of the turbo-charged engine and less risk of engine damage. This can be achieved with an optimized intercooler system installed between the turbocharger and engine. Construction of an intercooler? Intercoolers can be categorized by two types of the core construction. The BAR & PLATE core construction is relatively heavy so there is certain temperature inertia. Meaning under load the core takes longer to heat, but also longer to cool down once the load is removed. This is fine for on the road, but for use on the race track this core construction is not particularly suitable as it arrives at a constant cooling performance at varying loads in the full load range. Also weight reduction is an important consideration for track use. The fine structure of the TUBE & FIN core makes them relatively light and exchange heat much faster. This type of core construction takes temperatures relatively quickly, but also very quickly transfers this away again. For a constant cooling performance in a dynamic throttle situation this is an indispensable feature. Tube fin intercoolers are suitable for street use as well as at the race track. The OUTSIDE CORE is responsible for heat exchange with the running wind. The higher the density of the external core (fins), the better the cooling performance of an intercooler. But you also have to look which parts are behind the intercooler. Too much fin density means all parts behind the intercooler will be blocked. The worst case would be, you’ve solved the problem of high intake air temperatures, but the engine coolant temperature climbs. High performance manufacturers note all these factors and develop the most suitable structure of outside core design. Low Density Core // // // High Density Core Also notice the staggered offset fins for a larger contact area on the intercooler on the right The INSIDE CORE is responsible for heat exchange with the hot charged air and also need to handle the additional air flow which is running through the intake system. Care needs to be taken when deciding the internal fin density. A high internal fin density gives great cooling performance but with a high pressure drop. The pressure drop of the cooling system should not be adversely affected by an aftermarket intercooler. Less pressure drop reduces the mechanical load on the turbocharger (stability & life time for the turbo). High performance intercooler manufacturers find the best balance between high cooling performance, reduced pressure drop and design their intercooler cores specifically for each vehicle. The right ENTANK DESIGN is another key consideration when you are looking for the best intercooler for your car. It is easy to see the difference between a good and a bad aftermarket intercooler. There are different approaches, some manufacturers use sheet metal end tanks and others use cast aluminium end tanks. At flow velocities of around 100 m/s it makes no sense to let the air flow straight in to a wall. This causes unwanted turbulence inside the end tank and higher pressure drop. Furthermore, uniform filling of the intercooler is critical for optimum performance. To aid this, some manufacturers add internal air guides. Size & Fitment The size of an intercooler is not always proof of better cooling. There is an old adage which says "Power is nothing without control". This can be applied to bigger intercoolers. If you construct a bigger intercooler without working with internal air guide systems and flow optimized end tanks, the air will not flow through the whole system and choosing a bigger intercooler makes no sense because the intercooler is not being used effectively. Although the size of the intercooler is changing, the installation should not require mutilation of the vehicle. To avoid nasty surprises you should always look at the installation instructions (if available). Additionally you can seek reviews from neutral and professional sources. I know sometimes it is quite difficult to recognize those sources. Here is my advice on how to pick the right intercooler for you Don’t get an intercooler because someone on the forum says it’s cheap, it fits and they feel it is doing a great job. Ask for logs. Check if the manufacturer invests time and money in development/engineering, to get the latest technology in your intercooler. The needs of the cars and tuning them changes all the time. Don’t get an intercooler just because people say it is the best. Get an intercooler because professional tuners say it the best. The best intercooler on a fully bolt on car with upgraded turbo might not be the best intercooler for a stock car with stage 1 tune. Start by thinking ahead in terms of modifications that you will eventually add on your car. If you plan on going fully bolt on in 1-2 years, get an intercooler that suits the fully bolt on application. Bigger is not always better. If you do not plan on getting stage 2 turbo, don’t get an intercooler built for stage 2 applications. You want an intercooler that provides the best cooling with the minimum pressure drop. If the right intercooler is over your budget, wait until you have enough funds or try saving on other mods so you can get the right intercooler. Ebay Notes Some justify getting an ebay intercooler for the following reasons:
As mentioned above, getting a bigger intercooler does not always mean you are getting better performance. You might get better IAT than stock, but your pressure drop will be higher and so the couple hundred dollars you spent on a cheap solution did not help. If you are not going to pick a brand that takes into consideration everything mentioned above, you are better off keeping your stock intercooler. As i said earlier, dont get the biggest most expensive FMIC if your car is a daily driver with stage 1 tune. Talk to vendors / tuners, tell them your HP goals and mods + your budget. They will recommend an FMIC that suits your needs.
03-02-2016, 11:57 PM | #2 |
Rep 1,349
Drives: BMW F80 M3
Indeed i have said in my reviews before as well there is not 1 best intercooler. It depends on how you use the car and its mods.
Good writeup! |
03-03-2016, 01:07 PM | #3 |
Rep 845
Great advice. Always ask people who do this for a living -- they usually know more than you.
03-03-2016, 03:16 PM | #4 | |
Rep 190,777
Enjoyed your reviews as well
finessernicks0.00 |
03-03-2016, 03:18 PM | #5 | |
Rep 190,777
Make sure the person you ask offers a variety of brands so they can give you an honest opinion rather than just sell you what they have
BM235iW97.00 |
03-04-2016, 09:33 AM | #6 |
Rep 809
Great writeup mike, thanks for sharing it. In my personal case, I "think" I did a good investment with the Wagner Performance IC, I was told not to get the "Competition" model if I wasn't going to be doing track days often.
03-04-2016, 02:07 PM | #7 | |
Rep 190,777
Competition is more for track days. If you do not track your car often, performance is the way to go
07-05-2018, 10:34 AM | #8 |
Rep 190,777
07-05-2018, 03:41 PM | #10 |
Rep 190,777
It sure does
01-22-2020, 11:09 AM | #11 |
Rep 190,777
01-28-2020, 11:51 AM | #12 |
Rep 190,777
VRSF Intercooler vs stock
01-28-2020, 12:06 PM | #13 |
Bimmer Nut + Software Dev
553
Rep 802
Drives: 2018 Audi S3 IE Stage 1
Current: 2018 Audi S3 IE Stage 1
Past: '08 Infiniti G37S, '87 Porsche 944 Turbo, '13 328i, '15 M235i, '15 F80 M3, '16 M235i, '15 335i, '17 X5 xDrive35i @whoismorggan |
01-28-2020, 03:09 PM | #14 |
Rep 190,777
whoismorggan553.00 |
03-03-2020, 12:32 PM | #16 |
Rep 190,777
VRSF F chassis Intercooler
03-18-2020, 04:43 AM | #17 |
Rep 26
Can anyone please tell me what the fitment of the VRSF 6.5" Competition HD Intercooler is like in a 228i?
Is it worth getting the 6.5" over the 5" for Bootmod3 Stage 2? |
03-18-2020, 10:34 AM | #18 | |
Rep 190,777
Yes, it is. You're going to need the additional cooling that the 6.5" offer with stage 2 power
lmach61.50 |
03-18-2020, 04:04 PM | #19 |
Rep 4,137
03-18-2020, 05:32 PM | #20 | |
Rep 190,777
Wagner EVO III Competition CSF Evolution Racewerks VRSF 6.5" Competition VRSF 6.5" Race
04-17-2020, 11:26 AM | #21 |
Rep 190,777
VRSF 5" Intercooler HD
04-17-2020, 11:45 AM | #22 |
Rep 4,137
