02-14-2016, 10:11 PM | #67 |
Rep 1,084
OP, your setup looks great. Thanks for posting.
As others have noted, it's likely it'll rub on track. I used to run 18x9et41 with 255/35r18 Toyo Proxes R888s (which has at least 6mm less poke than your setup). This setup rubbed the rear fender in some corners, attached is a pic of such. This is stock rear suspension. Last edited by rwalker; 02-14-2016 at 10:44 PM.. |
02-14-2016, 10:37 PM | #68 |
Rep 647
Nice, doesnt poke that much, looks good... I wonder with 1/2" drop and 18/265 pss would clear with camber.?
02-14-2016, 10:41 PM | #69 |
Rep 444
Thanks for your input rwalker.
If a set up like yours, which is obviously pulling much more forces than anyone will on the street, sometimes rubs in those corners with stickier tires, I'm a lot more confident it is perfectly fine for my street set up. This is obviously not a set up for hardcore driving on the track, due to the size and weight of the rims. That's what my Kosei's are for. =D I also have a drag racing set up which I'm trying to get together right now. Having a hard time sourcing what I need though...
Quickest Stock Turbo F8x In The World
02-14-2016, 10:47 PM | #70 | |
Rep 444
rwalker What you think? I would never run these on the track due to weight, price of tires, etc.
02-14-2016, 10:53 PM | #71 | ||
Rep 1,084
I don't mean to sound discouraging. My rubbing wasn't a show-stopper; yours shouldn't be either. |
02-14-2016, 10:56 PM | #72 |
Rep 1,084
I can't speak from personal experience, but I'm pretty sure there's plenty room for 265s in the rear. Lots of folks run 'em, but most at higher offsets than OP.
02-14-2016, 11:50 PM | #73 |
Rep 28
02-14-2016, 11:57 PM | #74 |
Rep 1,503
Possibly, but I would get 5mm to be safe.
FBO M235i r
F80 M3 |
02-15-2016, 12:01 AM | #75 |
Rep 28
02-15-2016, 01:17 AM | #76 |
Rep 1,503
Correct. No bid deal though, just get some spacers. Almost every E36 racecar I've seen uses them.
FBO M235i r
F80 M3 |
02-15-2016, 01:25 AM | #77 | |
Rep 444
02-15-2016, 09:33 AM | #78 |
Rep 1,084
02-15-2016, 10:59 AM | #79 |
Rep 1,422
02-15-2016, 07:51 PM | #80 | |
Rep 28
I am looking for a bolt on fit that allows me widest tire possible (235/265) without any additional modifications (spacers, lowering, lca, rolling fenders, etc). |
02-15-2016, 11:39 PM | #81 |
Rep 1,503
It's a losing battle, just get spacers and move on. Either that or order some HRE's with custom offsets.
FBO M235i r
F80 M3 Last edited by ocN55; 02-16-2016 at 02:16 AM.. |
02-17-2016, 12:51 PM | #82 | |
Rep 1,084
I have not test fit my Apex 18x8.5et45 wheels without tires on my car, but I run 5mm spacers in order for my 255/35r18 tires to clear the strut (implying 255/2+40=167.5mm of inner depth from rotor hat face to strut at tire height). |
02-17-2016, 02:49 PM | #83 | |
BMW Lover
123
Rep 251
02-17-2016, 05:13 PM | #84 | |
Rep 133
I also wouldn't mind a photo or two of the front while you're at it. |
02-18-2016, 02:41 PM | #85 | |
Rep 1,184
This is saying it would poke out either 2mm or 4mm further than yours right? Do you think that would fit? Thanks |
02-18-2016, 04:56 PM | #86 | |
Rep 5,262
http://www.willtheyfit.com/index.php...et2=42#content http://www.willtheyfit.com/index.php...et2=44#content |
02-18-2016, 05:04 PM | #87 |
Rep 444
The rears would be perfect. The fronts will hit the suspension for sure though.
02-18-2016, 06:51 PM | #88 | |
Rep 1,184
Last two questions 1. If for some reason I did rub my fail safe would be a.) cut plastic shock cover back, or b.) sell 265s and go to 255s? (that would look fine on a 9.5 rim and have clearance right?) 2. 19x8.5 ET40 & 19x8.5 ET30 are the two offset options closest to what you have for the front. I would be willing to roll fenders if needed. Do you think 40, 30, or 30 with a 5mm spacer would be best. From what ive read I think 5mm works right? Would less than 5mm be a safer bet? Do those exist? |
