01-24-2020, 03:55 PM | #1 |
Rep 7
Drives: 2016 BMW M235i
Seafoam Valve Cleaner
Forgive me if this has been covered, I’m new to the DIY car world but have so far done all the work on this car myself.
I bought a used m235i with 38k miles and have upgraded everything to FBO. Decided I should try to clean the engine since I don’t know if that was done by previous owner. I’m using the spray can to clean the intake side and figured I’d just unhook the charge pipe, feed the little spray hose in, clamp it back up and follow the directions, but it seems the clamp is too tight and it’s just closed off the spray hose. Is there a trick to doing this? Can I do this into the air intake (passed the MAF), or will that hurt the turbo/FMIC? Appreciate the help
2016 M235i | Injen air intake | CSF intercooler | Fabspeed Sport Cat downpipe | M Performance exhaust
01-25-2020, 11:02 PM | #3 |
Rep 5,577
seafoam seems way too old a product type to be using on modern engines.
bmw has a technique for dealing with deposits, not even an issue on the 235 engine. |
01-26-2020, 12:11 AM | #4 |
Rep 736
Drives: Lexus RC F
Estoril Blue E36M3
01-26-2020, 10:00 PM | #5 |
Rep 7
Thanks, decided it wasn’t necessary after doing a little more research
01-27-2020, 07:47 AM | #6 |
Rep 2,214
Maybe a walnut blast at 100k miles, but I haven't seen anything really suggesting its necessary on the N55. Helps running good fuel and driving it hard each heat cycle
