01-10-2020, 10:07 AM | #1 |
Rep 348
Front tires warmer than rears
Not sure if this is the right thread, but i'll give it a shot. Hey all, I own a 2020 m240i and have noticed that my front tire temps skyrocket after "spirited driving." Car is completely stock with oem wheels and fitment. Why would my front two tires get warmer than the rears in a RWD car? Car does not have an LSD if that matters.
01-10-2020, 11:15 AM | #2 |
Rep 237
Mine do the same. The front wheels will build up more heat when turning at speed and also under braking. It's normal. Unless your roasting the rear tires you can expect that temp difference
01-10-2020, 04:03 PM | #4 | |
Rep 5,262
kianf2264.00 |
01-10-2020, 04:32 PM | #5 | ||
Rep 348
01-11-2020, 09:28 AM | #6 |
Rep 294
Drives: 2019 M240i Coupe RWD
If you turn the steering too hard and understeer, you are scrubbing speed off with the front tires, essentially skidding them. That will make a noise and rapidly build up heat in the tires. Is that what you are doing?
kianf2264.00 |
01-12-2020, 12:33 PM | #8 |
Rep 348
Thanks a lot for the replies! Any reason I experience this more in the wet? Or does it have to do with it being cold out?
02-20-2020, 05:12 PM | #9 |
Rep 2,872
DK if it is really answering 'why' but they just published an article in C&D about how Porsche uses acoustical sensors in the wheelwell to determine if road is wet or dry, so it isn't just you noticing the difference.
02-20-2020, 07:52 PM | #10 |
Rep 345
Not to throw out the obvious: but did you reset your TMPS system since the last time you rotated your tires? Maybe iDrive has your fronts and rears backwards
02-20-2020, 08:01 PM | #11 |
Rep 653
02-24-2020, 11:47 AM | #13 |
Rep 653
The 2 series shows the air temperature of the tires? That is interesting, I'll have to check that out this afternoon.
02-24-2020, 11:51 AM | #14 |
Rep 736
Drives: Lexus RC F
I thought that was normal since the engine is closer to the front tires.
Estoril Blue E36M3
02-24-2020, 03:21 PM | #15 |
Rep 345
I'm not sure about the year breakdown, but I think 2017+ F series will show the tire temp as long as its turned on as an option in iDrive. Before 2017 you might have to turn it on by coding.
02-28-2020, 10:35 PM | #16 | |
Rep 145
Maynard3846.50 |
