01-07-2020, 08:30 PM | #1 |
Rep 31
Need to empty fuel tank
Does anyone know of any way of me being able to empty my fuel tank? I have a whole tank of 93 that I need to empty to fill with e85 again.
01-11-2020, 04:48 PM | #2 |
Rep 198
sure a fluid transfer pump need to make sure it can be used with gas there are several on the market you will also need several 5 gallon fuel cans. its probable just cheaper to drive the car and fill back up with E85
01-14-2020, 07:36 AM | #3 |
Rep 237
↑its a wicked hassle to drain modern tanks, much easier to drive it down. There's a check ball (rollover) that makes it difficult to get a hose down the filler. I had to drain gas out of an f80 M3 last year and ended up pulling a fuel line and running the pump in 5 second bursts with a scan tool until I got most of it out. Took forever. The dme won't let you continuously command the pump on. You might be able to use a power probe to supply it with 12v at the sender but...easier to just drive it
