01-07-2020, 01:38 PM | #1 |
Rep 1,078
Clutch clicking
Over the past year or so, I've noticed that my clutch would "click" occasionally when I am changing gears and only happens as I am pressing into the clutch. Has anyone experienced this as well? It doesn't happen all the time, but enough times for me to notice it. I would say it's usually within the first 3 gears. I'm wondering if that means I should be looking into replacing my clutch. I am currently at around 60K miles.
01-07-2020, 02:12 PM | #2 |
Rep 599
My car does this when it's very cold. I've passed it on as normal.
2015 F80 M3 DCT, Carbon Roof
1998 S54 E36 M3 BMWCCA Club Racing #532 CM 1995 E36 M3 Sunbelt S52 |
01-07-2020, 02:34 PM | #3 |
Rep 5,577
Even though this was discussed earlier -someone stated they went to dealer and tech said this is normal I also get the click, noticed it in my parking garage - the noise doesn't sound to me like an issue/defect more like a mechanism working.
It's funny...this morning was listening to my engine idle, then while out listened to another engine in a X3. When you hear the same model engine in different cars make it's usual noises it is almost like music. |
01-07-2020, 03:36 PM | #4 |
Rep 1,078
Found a similar issue on the M2 forums, not sure if it's the same issue, but it does sound very similar. They determined it was the clutch master cylinder.
https://f87.bimmerpost.com/forums/sh....php?t=1622299
01-09-2020, 04:18 PM | #5 | |
3441
Rep 79,211
To the OP: If you want to see if the clutch is slipping, get a clear path on highway, go about 35 MPH and go WOT in 4th gear. If it's going to slip, it's going to do it then. Do these cars have Clutch delay valves? If so, get rid of those too. They were nothing but problems in the E9X. |
