2Addicts | BMW 2-Series forum Technical Topics DIY and Coding Discussions Coding with bimmer code
      12-25-2019, 08:38 PM   #1
pmcmtnbkr
pmcmtnbkr's Avatar
106
Drives: BMW M235I
Had my first coding experience today with bimmer code installed a 8.8 inch display and changed a few of the display functions overall it was a good experience. However I notice that there was a module in the coding that instead of being green like all the rest had a yellow dot before it. It was the section for the automatic AC functions. It was this way prior to any coding that I did and continue to be yellow after the coding I did. I can find very little info on this or how to correct it. Can anyone enlighten me on what this yellow indicator means. I picked this car up used so don't have much idea what was done in the past if anything coding wise. Ac has worked great. I have noticed the ocational change in the indicator for auto to manual air circulation appearing to change on it's own.
      12-26-2019, 08:00 AM   #2
Climate Changer
Climate Changer's Avatar
2018 230i xdrive co ...  [0.00]
2019 x3  [0.00]
I never seen it yellow only grey, green or red. Email Stephan at Bimmercode. They are very responsive.
      12-26-2019, 09:20 PM   #3
pmcmtnbkr
pmcmtnbkr's Avatar
106
Drives: BMW M235I
thanks i will give that a try. I did find a old post on another forum last night with the identical code error on this module. sounds like it is just an odball problem that can arise with this module.
      12-27-2019, 02:55 AM   #4
Poochie
Luxury at the redline :)
Poochie's Avatar
Drives: 2016 M2
There in some sort of fault code stored within those individual module. It's very likely the hardware was previously replaced an not programmed to module properly.
You have to run a Test Plan with something invasive like ISTA+ to see what shadow code(s) are being reflected for those modules.
      12-27-2019, 09:35 PM   #5
pmcmtnbkr
pmcmtnbkr's Avatar
106
Drives: BMW M235I
that sounds like it is well out of my ability level. I saw nothing of value to try and program in the demo mode of bimmercode. As long as things continue to work i might just leave well enough alone.
