2Addicts | BMW 2-Series forum Technical Topics DIY and Coding Discussions Retrofitting Electric/Power seats?
      12-07-2019, 12:40 AM   #1
Sisyrx
Budget Enthusiast
Sisyrx's Avatar
243
Drives: 2017 230i M-Sport
2017 BMW 230i  [0.00]
Looking for any insight into retrofitting electric/heated seats into my manual/heated seat F22.
Control modules aren't an issue (included/attached to seat) but more curious regarding the remaining level of effort...wiring/coding/parts?
Seeing threads for other chassis and wondering if it's still so involved in an F22.
2017 230i // Estoril Blue II // M-Sport
      01-22-2020, 03:45 PM   #2
Ad-330i
Drives: e92 330i
Recently done this to mine, had to run 3 new wires to each seat, new climate panel then coding!
      01-22-2020, 03:47 PM   #3
Sisyrx
Budget Enthusiast
Sisyrx's Avatar
243
PM me? I shouldn't need the climate panel as I'm already wired/coded for heated seats. Would only be adding power/memory.
      08-25-2020, 03:26 PM   #4
perzonal
Drives: BMW M2
2017 BMW M2  [0.00]
Did you find out? Probably going the same way in my M2 that should be the same as the regular 2 series. Mind sharing a guide?
      08-25-2020, 06:18 PM   #5
Sisyrx
Budget Enthusiast
Sisyrx's Avatar
243
Kinda, but I never got part numbers. Essentially they tapped into the pins in center console.
I wasn't too keen on messing with the bus wiring while under warranty, so I did not pursue.
      08-26-2020, 07:32 PM   #6
perzonal
Drives: BMW M2
2017 BMW M2  [0.00]
Okay, thanks 😊
      01-25-2022, 02:52 PM   #7
acyeomans
Drives: Bmw 2 series
Hi, I'm looking for some advice on retrofitting heated seats to a 2016 f22 218i. The car currently has non heated fabric seats. I understand I need to get the heated seats with control modules as well as the AC unit with heated seat buttons. I also understand these need to be coded in. What I'm unsure on is if there is any wiring required between the seats and the car or if this is simply a case of plug and play?
      09-09-2022, 01:51 PM   #8
Spannerman63
Drives: Bmw M2
Urgent help required
Hi, can you please tell me what 3 wires are required to be fitted to get the electric seats wired up ? Just got a set of the seats for my M2 but no specific info on line on how to wire them up.
Appreciate any advice that you can offer
