11-21-2019, 03:26 PM | #1 |
Rep 190,750
Active Autowerke N55 Catted Downpipe , No CEL Guarantee!
ACTIVE AUTOWERKE BMW N55 DOWNPIPE BMW introduced a new valvetronic, single turbo version of its direct-injection engine for the F-Chassis models beginning in 2012. The Active Autowerke N55 downpipe for the M235i, 335i, 435i and M2 helps unleash some of the potential that is restricted by the OEM downpipe. Turbochargers are powered by spent exhaust gases created during the combustion process. The quicker these gases are evacuated, the better. Unfortunately, the factory down pipe in the N55 is quite restrictive, which results in slower exhaust gases and slower turbo spool. The Active Autowerke F-Chassis N55 Signature down pipe utilizes 3.5” diameter stainless steel piping in order to provide more power, quicker spool, and extreme durability. This variant includes a 49-state legal EPA approved 4.5" high flow GESI catalytic converter that will NOT produce a CEL! EPA N/GBL/4389/1119 FEATURES:
The speed of a turbo’s impeller wheel is limited by exhaust back pressure. A larger down pipe relieves some of this pressure, resulting in quicker and more efficient spool. With Active Autowerke’s Signature downpipe, your N55 can rev quicker, and deliver more horsepower and torque. Minimizing back pressure while remaining daily drive-ability was the goal of our N55 downpipe. Owners can now upgrade to a product that is affordable, reliable, and easy to install. After months of research and development, our engineers settled on a 3.5” diameter pipe which utilizes the least number of bends possible. However, the Signature N55 down pipe still fits easily into the OEM location, with a painless installation process. Constructed entirely from 304 stainless steel with 1.5MM wall thickness, we are confident that you’ll be pleased with how robust and durable this down pipe is. Trouble-free installation and a long lifespan ensure that you’ll enjoy many miles of performance with your N55!
https://x-ph.com/sale/ Phone number 702-494-9435 Last edited by mike@x-ph.com; 01-02-2020 at 05:41 PM.. |
11-23-2019, 12:12 PM | #3 |
Rep 190,750
Correct its no CEL guarantee + EPA approved.
11-23-2019, 12:59 PM | #5 |
Rep 190,750
No tune is required, if course with the right tune you get even more gains since you can run stage 2 maps
11-24-2019, 11:16 AM | #8 |
Rep 190,750
its only the 4"
Fitment:
11-27-2019, 10:49 AM | #9 |
Enthusiast
84
Rep 229
Nice Work. Appeals to those of us that want to upgrade performance without emissions issues. I went catless once, would never do it again!
_______________________________________
2016 M235i XDrive Estoril Blue/Black |
11-27-2019, 06:04 PM | #10 |
DisplacementReplacement
406
Rep 1,100
This looks very promising and a great solution.
2020 X3M /// MHD Tune
Prior Bimmers 2017 240XI Hybrid / FBO / MHD E40 2015 235XI FBO / MHD E30 2009 335XI FBO / COBB / E30 |
11-30-2019, 03:28 AM | #11 |
Rep 4,134
So why is it 3.5 and not a 4”?
Mods: Yes.
11-30-2019, 08:57 AM | #12 |
406
Rep 1,100
Not available for x drive from what I can tell.
11-30-2019, 11:20 AM | #13 |
Rep 190,750
RWD and Xdrive downpipe fitment is the same
11-30-2019, 11:21 AM | #14 |
Rep 190,750
the connection is 4" , the pipe between the connections is 3.5"
12-16-2019, 09:03 PM | #15 |
Rep 1,794
Drives: F30 328i M 6mt, E36 M3
Will this downpipe lower underhood temps a little - higher flow, less heat bound up in the dp so close to the motor -
Thanks!
12-17-2019, 11:26 AM | #16 |
Rep 190,750
Any downpipe with higher will lower heat
12-28-2019, 02:35 PM | #17 |
Rep 674
Anyone have issues with warranty from BMW with this install ?
Not sure if/when I'll tune, but interested in a bit more power...this seems simplest. Guessing need to do charge pipe at same time. |
12-29-2019, 11:26 AM | #18 | |
Rep 190,750
The warranty is only effected if the mod is to be blamed for damaging a stock component. In the case of downpipes, on its own it does not add any pressure on other components. On the contrary with higher flow cats, it reduces backpressure on the turbo
01-19-2020, 11:29 AM | #19 |
Rep 190,750
01-20-2020, 08:39 AM | #20 |
Rep 5
Always Recommend buying from X-PH
mike@x-ph.com24177.50 WolfGTI716.00 |
01-20-2020, 10:10 AM | #21 |
Rep 190,750
