2Addicts | BMW 2-Series forum BIMMERPOST Universal Forums Off-Topic Discussions Board Video + PC Gaming / Computing Issues with Asus ROG STRIX RTX2070 OC
      10-23-2019, 02:21 AM   #1
Dang3r
Schmollbraten
Dang3r's Avatar
Germany
12503
Drives: M4CPC // HP4 Comp.
So I bought this card few weeks ago and installed it into my workstation, starts up fine, no problems so far, started the first game (Division 2) and after a few minutes the screen freezes and was only to solve by hard reset.
New try with Diablo 3, same effect.
Returned the card to the dealer, yesterday it came back, after reinstallation I got first after few minutes a blue screen, than at second attempt it runs until I started Division 2, then suddenly some coloured artifacts appear and the screen went down.
Read a lot of problems with this series afterwards into forums, its still a very good card (at user who run it w/o problems), but I think I return it now finally and look around for replacement.
Any suggestions? Anyone else encountered this?
Citizen of ///M - Town, where too much is just right
Some say, that my scrotum has its own small gravity field and when Im slowing down that brake lights come on at my buttox
      10-23-2019, 02:48 AM   #2
archerz
United Kingdom
374
Drives: F31 335D
Sounds like a driver issue somewhere. Try the latest drivers for the card (but also try a previous version too).
You can use DDU (Display Driver Uninstaller) to make sure no residual drivers are there from previous versions.
Also worth checking other drivers on your PC, like chipset/mobo etc.
Dang3r12503.00
      10-23-2019, 03:08 AM   #3
antych
United Kingdom
246
Drives: 2017 BMW M4CP SO
2014 BMW M4  [10.00]
Be careful with the Division 2, a lot of people report crashes with DX12, so make sure to run it in DX11 for now. You also need a high quality PSU in case you've upgraded from something low end.
Dang3r12503.00
      10-23-2019, 07:18 AM   #4
Conissah
Conissah's Avatar
1575
Drives: 2018 M3
Highly unlikely 2 different cards are bad. Most likely a software issue. Boot into safe mode and do a clean install of your driver. If you have shadowplay running, or even GeForce Experience, try turning them off and then running the game. I have also had bad luck with GPU software (Msi Afterburner, EVGA Precision X, etc.) impacting games and causing weird issues. Try killing those processes as well. Try a different game and see if you get any odd issues. Tons of possible issues, so it just comes down to trial and error.
Dang3r12503.00
      10-23-2019, 08:09 AM   #5
R3dliner
R3dliner's Avatar
Drives: 18 M3 6MT
One of the reasons I stayed away from the Asus gpu's. Picked up a MSI version and never looked back.
Dang3r12503.00
      10-23-2019, 08:36 AM   #6
Redd
Drives: 2010 BMW E92 M3 Dakar Edition
Only use Nvidia drivers. Don't use the Asus drivers.
Dang3r12503.00
      10-24-2019, 02:15 AM   #7
Dang3r
Schmollbraten
Dang3r's Avatar
Germany
12503
Appreciate your comments and inputs, will give the DDU a chance.
All drivers (MB and rest) are up to date, read somewhere that nVidia 419.37 should work perfect, will try also and come back with the results.
No Asus drivers installed so far, aside of clocking and fan speed adjusting, but not used them.
Thanks, folks.
      10-24-2019, 11:33 PM   #8
RED_Y_
Drives: 2014 X5 3.5d
Is your power supply strong enough? Any temperature issues? Did you check windows logs to see what BSODs are related to?
      10-25-2019, 01:26 AM   #9
AlpineWhite_SJ
Drives: 2018 F80 M3 ZCP, 2020 F97 X3MC
Update all the things - bios, windows, etc. remove all aftermarket software and just run latest driver package. Do clean install of drivers when installing. Beyond that, I’d check PSU since plenty of GPU issues end up being PSU related. If it was just one card I’d blame the card but not twice - there’s a weak link somewhere. Also try running the card in a friends system to see if you get the same issues.
      10-25-2019, 01:40 AM   #10
Dang3r
Schmollbraten
Dang3r's Avatar
Germany
12503
We had installed the card meanwhile into 2 complete different systems, at the first one 2 bluescreens instantly after starting at the second artifacts instantly after starting.
Card returned the second time to dealer for exchange on warranty. If that fails, I got my money back and change cardtype and brand.
Just to complete: I own a 750W power supply, its strong enough.
      10-25-2019, 01:55 AM   #11
AlpineWhite_SJ
Wattage only means it "should" be able to handle it. It really doesn’t mean anything - it could be a bad rail or the stress of the card causes issues. How much load are the other system items adding?
That you had issues across systems either means you have two weak systems, or the extraordinary bad luck of getting another bad card. Strictly speaking, ASUS Strix cards usually are pretty good. My 980 strix ran for years with no issues and I still have it as backup in case my Titan Xp craps out
      10-25-2019, 01:58 AM   #12
Dang3r
Schmollbraten
Dang3r's Avatar
Germany
12503
I hear you, but the power supply is a very good one which supplies really enough, that isn't the problem.
2 corrupt systems maybe but not 3 in a row.
Search for artifacts at the strix 2070 OC and you'll find lots of entries. Seems like I got one of the very first edition where this happened a lot
Meanwhile I have to return to my Asus GTX680, also a really good card but the newer the game, the lower the graphic settings.
      10-26-2019, 10:01 PM   #13
Conissah
Conissah's Avatar
1575
Drives: 2018 M3
Go to the red team. Haven't looked back since I purchased my Radeon VII.
      10-28-2019, 07:06 PM   #14
Solidjake
¯\_(ツ)_/¯
Solidjake's Avatar
Poland
945
Drives: '13 328i Msport 6MT
I have a Gigabyte 2070 super with no issues in the two months of ownership. It's paired with an Evga G2? 850w psu
Tensioner/belt DIY | Side skirt extension DIY
Apex SM-10/DWS06+ | 400m/X-ice Xi3 | Injen Exhaust | Stoptech SS Lines | 335 Front Brakes
Hawk HPS 5.0 | RBF600 | ER Charge Pipes | Wagner Evo Comp 2 FMIC
      11-02-2019, 10:16 AM   #15
Hurricane1122
Drives: eclipse
A lot of the new 20xx series cards have defects, if i were you i'd just buy a used 1080ti thats what i done a year ago and its been running beautifully. Im even thinking of getting another one and a 4k monitor.
Search this Thread:
