2Addicts | BMW 2-Series forum Technical Topics Cosmetic and Lighting Modifications Scratches on coating on speedometer...
      10-10-2019, 04:20 PM   #1
TINY BMW
Drives: 2019 M240i xDrive Convertible
Pretty pissed. Cleaned the speedometer the same way as the big display in the middle, which looks flawless. This coating is definitely inferior.
View post on imgur.com
It's on a Convertible, so it's very noticeable when the top is down (I literally can't read part of it...)
Change of getting this replaced under warranty?
      10-10-2019, 06:45 PM   #2
overcoil
Drives: M235i 6spd
what products and applicator did you use ?
Is it possible you stained the plastic ?
      10-11-2019, 11:32 PM   #3
TINY BMW
Just a microfiber cloth, the same one I used to clean my old 135i's speedometer, and my current M240i's main display. No scratches there.
      10-12-2019, 10:32 PM   #4
sandrik93
Drives: '23 M240i RWD
Mine has the same thing and I've seen a lot posts online about this. Sadly, no solution yet other than replacing. Sucks...
      11-09-2019, 02:15 PM   #5
DaleHeinz
DaleHeinz's Avatar
221
Drives: M240Xi Estoril Blue
You need a lubricant with microfiber. I use an interior cleaning spray from Griotts with the microfiber. Otherwise, you're just dragging dirt across the plastic screen and will no doubt get scratches.
