2Addicts | BMW 2-Series forum Technical Topics Mechanical Maintenance and TSBs: Break-in | Oil & Fluids | Servicing | TSB windshield washer fluid slow refill
      08-23-2019, 01:15 PM   #1
kriszty
kriszty's Avatar
329
Drives: B58 M240ix pureturbo800 dorch1
After intensive use of my window washer , i wanted to refill my washer fluid, but how in gods name to refill ?? , if i poor a small bit of fluid in the reservoir it takes 2 minutes for maybe just 10cc of fluid ... is there some fix for this ?
bmw m240i xdrive 2017
      08-24-2019, 12:25 PM   #2
msej449
msej449
msej449's Avatar
United Kingdom
514
This doesn't sound right - no doubt as you suspected. I can refill my reservoir with a minute or so of pouring. Although the fill rate is relatively slower than most cars with a wider funnel.
Question: Have you been using BMW washer concentrate, or some other product? Some owners report slow fluid flow after mixing BMW with non-BMW washer fluid - there are a number of extensive threads on this.
2023 Peugeot e-208 GT (electric)
      08-25-2019, 12:43 PM   #3
kriszty
kriszty's Avatar
329
i used non bmw washer fluid, but it was my first refill, so the problem was already there i think, i will take it to the dealer next week for checking. i will let know what the result is. thanks for the answer
      09-05-2019, 05:21 PM   #4
biz4two
Drives: 2014 f22 n20 228i
Question
OP ... What did the dealer find?? Is the situation resolved?
biz
2014 BMW 228i f22 n20
Prod.date: 2014-06-27
      09-12-2019, 12:41 AM   #5
darkshard
Drives: bmw 535xi, 240i
I use the orange rain x purchased from walmart.
      09-12-2019, 07:31 AM   #6
Climate Changer
Climate Changer's Avatar
2018 230i xdrive co ...  [0.00]
2019 x3  [0.00]
Never use rain x or any other washer fluid that has similar properties. It will gunk up the sensor and you will have issues. Only use either BMW washer or the cheap blue stuff
      09-27-2019, 12:25 PM   #7
MAILIYAT
Drives: MUSTANG
i used non bmw washer fluid, but it was my first refill, so the problem was already there i think, i will take it to the dealer next week for checking. i will let know what jiofi.local.html the result is. thanks for the answer
      09-27-2019, 01:13 PM   #8
kriszty
kriszty's Avatar
329
biz
yep, they replaced the fillbox, they said it was a common issue , no further details i got. but now it works
