06-02-2014, 01:15 PM | #23 |
Rep 319
not sure if you have looked into bavsound? I was just wondering since they offer a pair of 25mm silk tweeters for about 189 and as well as mid-ranges.
Just curious if you know how does your focal compare to the bavsound |
06-02-2014, 11:24 PM | #24 |
Rep 900
Would you be willing to post a DIY with a list of tools/parts needed, and the relevant specifications to look for in the new speakers?
06-03-2014, 09:09 AM | #25 |
Rep 6,926
Drives: 2018 M2 AW DCT
I have never knew anyone who actually had bavsound to compare. The Focal's are a well known, well respected, established speaker carried by many retailers.
06-03-2014, 09:12 AM | #26 | |
Rep 6,926
As stated earlier, the speakers are four inch speakers in both the doors and back deck. |
06-03-2014, 05:16 PM | #28 | |
Rep 6,926
Here is the link to Crutchfield: http://www.crutchfield.com/S-pAyzIGn...&awmt=e&awnw=g |
06-13-2014, 02:39 PM | #29 |
Rep 30
Really want to do this myself instead of blow $200 on install (yes Im cheap) I have built my own speakers just need some help.
1. Can you describe how you get open the speaker lid? (nervous of doing this on a 50 k car) 2. What is the size of the spacer used? 3. What did you use as a spacer from wood or buy one, if so what one? (one like this?) http://www.sonicelectronix.com/item_...sche-SA68.html |
06-16-2014, 12:04 PM | #30 | |
Rep 319
06-16-2014, 12:36 PM | #31 | |
Rep 6,926
06-16-2014, 12:54 PM | #32 |
Rep 2,337
If you have access to a router, making MDF rings is easy. I have a Jasper jig for stuff like this. You could also use rubber washers and expanding foam to make a spacer that will work. A kit with a door panel remover is also worth it.
08-21-2014, 11:22 PM | #33 | |
Rep 765
Also, did you keep the stock subs or replace them too? Did the stock system have a center channel speaker in the dash? Amp - did you upgrade or just using the stock head unit? With the stock system, did you do anything to put the tweeters in the doors up high behind the mirrors? Sorry about all the questions, but I'm trying to decide on the HK or go aftermarket. If Focals are really that much better than HK, then I'm better off saving the $$ and just installing aftermarket components. |
12-18-2014, 03:29 PM | #34 | |
Rep 115
After hesitating, the installer went out to look at my car and said he'd need to build brackets for the doors AND the rear deck. He was also adamant that they have never installed speakers on a 2-series. I'm now waiting for them to finish. They ended up charging $240 for two pairs after first wanting $300. I didn't expect a car-buying experience, but that's what I got. I probably got ripped off a little, but it's not worth reflecting over except this one time as I type this. |
12-18-2014, 05:47 PM | #35 | |
Rep 2,337
12-18-2014, 07:56 PM | #36 | |
Rep 765
12-18-2014, 09:32 PM | #37 | |
Rep 6,926
Mine were installed in early April. |
12-19-2014, 09:43 AM | #38 | |
Rep 272
There are some brackets available but you will have to use smaller 3.5" speakers. Here is a picture of rear speaker install. I have detail on install on another thread. |
12-19-2014, 04:14 PM | #39 |
Rep 115
I am pretty happy with the Focal 100 speakers. The experience was shit, and glad I don't have to do that again. I'm now in the middle of getting tinting (Formula One Pinnacle, 30%). This is a much better purchase experience.
Next up: mounting my winter tire set! |
12-19-2014, 08:28 PM | #40 |
Rep 118
Is that hole next to the speaker in the rear deck for a factory tweeter? Just a recommendation to seal it up. Even though the speakers are small and in a leaky rear deck, the more you can separate (seal) the front wave from the back will improve bass/midbass response. A piece of dynamat works ok. Same goes for the door mounting. I sealed the rear deck for my neighbor in his sedan while replacing his torn up stock speakers with cheapy Pioneers (4") and he thought I installed a subwoofer for him.
12-19-2014, 11:00 PM | #41 | |
Rep 272
Also there is no holes on the grill below tweeter area so speaker grill will need to be replace with one from HK set if you want to use separate tweeter. Replacing rear speakers alone makes a huge difference on the upper bass response. |
12-27-2014, 03:32 PM | #42 |
Rep 2,337
I haven't replaced the door speakers yet, but I bought a set of Jehnert Flatline speakers which come as a 3way setup. 1" tweeter, 4" mid, and 8" woofer. I have replaced the oem underseat subs with the ones that came with the kit. They're not even getting any more power than the stock base system and haven't had time to break in, but they already sound way better. They also help clean up the overall sound of the entire system, as they don't muddy things like the stock subs do.
I can only imagine how much better things will sound once the entire kit is in, and how much louder it'll be with some power. Already they hit way harder and dig deeper into the sub range, while being super detailed and transitioning bass, mid bass, and kick drums. I'm very impressed so far. Eventually I might take the advice of the reseller who sold me these and buy the Match PP82DSP.
01-19-2015, 09:30 PM | #43 |
Rep 30
IC 100
I have a new M235i with the stock stereo and it is truly lousy. It is a poor resolver of music.
I would prefer to change the 4 inch speakers only and improve sound quality only not a wholesale replacement of the system. Would you mind taking a moment and quantify the difference between stock and the Focal ic 100. All around better resolver? Tighter/fuller base? What about integration with the subs? Is it as good by chance or better or worse? Thanks for your assistance |
01-20-2015, 12:41 PM | #44 |
Rep 2,942
My advice ...
... based on researching:
- Several 4" models will drop in direct to the rear deck, including the Focal 100s and the JL Audio C2-400x (my initial choice; now opting for Hertz Energy 100.5s). - Most of those same 4" models will work great in the doors with a spacer. Member CAF10 sells an E30 spacer, which works for an F22 as well, for $25 or $30 on the 'bay. akuan99 used these in his install. - Use a reputable installer for the door install. Do the rest yourself. - Finally, disconnect the center speaker on the dash. It isn't worth replacing and improves the soundstage. Last edited by Viffermike; 02-06-2015 at 05:32 PM.. |
