2Addicts | BMW 2-Series forum Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics 2014 M235i non HK sound system question
      07-28-2021, 10:48 PM   #1
shanedawggg
Drives: 2014 - M235i
Hey guys,
Just got my new car and loving this place as a source of info
I have used the search function to try and find my answer, but wasnt able to.
I have a non HK M235i and would like to upgrade the audio. Ive read the threads with the suggestions and i like the look of them, but my question is around the tweeters for the front. Does the non HK have all the wiring required to mount and install a tweeter on the inside of the mirrors? I figure that i will have to buy the OEM sails (the mount for the tweeter) but not sure if everything else that i need is already in the door.
If someone can please confirm and if anyone has a suggestion on where i can find the sails (without HK tweeter) that would be amazing.
Thanks all.
Cheers,
Shane
      07-29-2021, 08:36 AM   #2
MarcoZandrini
Drives: 2018 M240i
Each door has a single pair of wires for both the mid-range and the tweeter, regardless if the car the HK sound system or not. What BMW does it places a capacitor in series with the tweeter's wires to block audio frequencies below a specific frequency. So, if you buy component front speakers the kit will include either capacitors or actual crossovers.
      07-29-2021, 06:51 PM   #3
shanedawggg
Thanks of the reply Marco! So i just need to get the sails/housings?
Cheers,
Shane
      07-30-2021, 08:50 AM   #4
MarcoZandrini
Drives: 2018 M240i
Yes! There's foam on the inside of the housing. The foam has a cut out for the tweeter. You can cut out additional foam if you need to.
