09-17-2016, 01:19 PM | #265 | |
Rep 447
09-25-2016, 05:53 AM | #266 |
Rep 125
After reading this thread on many occasions I decided to spend some money and go for the speaker changes. I tackled the rear shelf speakers first and replaced the HK speakers with the JL Audio C2 400x. I cut off the BMW speaker connectors and soldered on the spade connectors for the JLs without too much difficulty although soldering inside the car with not a lot of wire to play with meant I had to be very careful.
I then got to work on the front doors to fit the Eton speakers and my troubles started. On the drivers door the torx bolt behind the door opening handle just continuously spun while I tried to remove it. Eventually I was forced to unclip the door panel and while pulling on the panel I managed to get the torx to unscrew from the mounting nut. As the torx finally released itself from the nut it was followed by the rattle as it fell off inside the door. Once I had the panel off, I removed the sound proofing from the lower half of the door in an attempt to recover the nut but I was unable to find it. After fitting the speakers, I reattached the door panel minus the one screw as I didn't think it would be a problem. This morning I decided to do the passenger side to complete the job. Once again, the torx behind the door opener is spinning and also one of the screws behind the handle trim is also doing the same I've had to stop until I can get to a BMW dealer and source the replacement torx nuts that mount in the door and I still have the problem of trying to get the 2 torx screws out. Hopefully pulling on the clip released door panel will work because there is no way I can get something down the recess on the door handle to pull on the screw as I try to remove it. To say I'm frustrated is putting it mildly. Has anybody had similar issues or have I just been unlucky? Anybody out there know the part number of the torx nut mounts that I will need to get? Any help, greatly appreciated. |
09-26-2016, 12:41 PM | #267 | |
Rep 47
There is a pretty huge range of 4" component sets out there from very good companies, it all depends what you are looking to spend. Hybrid Audio, Helix, Morrel, Audison, Hertz, far too many to list off all of them. |
09-26-2016, 01:39 PM | #268 | |
Rep 6
09-26-2016, 02:53 PM | #269 | |
Rep 125
09-29-2016, 04:24 PM | #270 |
Rep 465
Harness Fix
I finally was able to do the harness fix. If you have a harness that has not been corrected by Technics you really should do this. The system sounds much different, with lots of mid- and lower-bass. I've changed my settings accordingly:
Treble: +3 or +4 clicks, depending on source Bass: -3 or -4, depending on source Balance: 0 Fader: 2 to rear These are for high volume settings, somewhere around 80-90%. These settings take advantage of the added bass and punch without muddying things up. I now understand why my ears were telling me to set the balance to favor the left side. That adjustment is no longer needed. Makes me appreciate the Technic harness all the more. |
BentZero624.50 |
10-02-2016, 12:02 PM | #271 |
Rep 71
Harnes fix
Switched the white and black/white wires on the harness yesterday. Nice bump in bottom end. But, in addition, there seems to be enhanced clarity of sound at both the low and high ends. Wonder if others have noticed this? If so, maybe there is muddle related to the cross wiring?
10-02-2016, 02:48 PM | #272 | |
Rep 465
I wonder whether anyone can hazard a guess or even an answer based on the schematic about what might account for this. The system as a whole sounds lots better. I'm really enjoying listening to the audio in the car now. |
10-02-2016, 03:07 PM | #273 | |
Rep 780
10-02-2016, 03:16 PM | #274 |
Rep 465
Yes, just cut two wires, cross-connect and protect with connector caps or even (gasp) electrical tape. For instructions on various methods see posts above.
10-02-2016, 03:27 PM | #275 |
Rep 780
Where is the actual harness located- forgive my ignorance lol
2014 AW M235i Sold
2013 BLK GT500 track pack/ perf pack/ recaros |
10-02-2016, 03:59 PM | #276 | |
Rep 465
The original version of the harness had a minor wiring issue that requires the correction mentioned above. If you order a new harness from Technic you'll get a corrected version that won't need any alteration. The installation is straightforward. If you look through this thread you'll find the information you need for ordering along with links to a handy installation tutorial. |
10-02-2016, 04:22 PM | #277 | |
Rep 780
2014 AW M235i Sold
10-04-2016, 07:23 AM | #278 | |
Rep 465
10-07-2016, 02:10 PM | #279 |
Rep 125
Initially I decided to swap out the speakers as mentioned in this thread - Eton up front and JL at the back. When I had managed to complete the speaker swap outs I was even more frustrated by the ASD hiss. So reluctantly I bought the ASD harness to see if it could provide any improvement. After fitting the harness today, all I can say is why didn't I do this first? Suddenly the sound has burst into life, no annoying background hiss and a real clarity to the sound. Without this thread I would never have found the 'solution' so thanks to all who have contributed to this great improvement to the F22 sounds
Viffermike1753.00 |
10-07-2016, 08:31 PM | #280 | |
Rep 465
10-15-2016, 02:05 PM | #281 | |
Rep 99
Right (looking towards the front of car): -Wire 1:Yellow with black stripe -Wire 2: Yellow with black stripe and some dots Left: -Wire 1: White with black stripe -Wire 2: White with black stripe and some dots Not sure which is positive or negative. I think the black dots indicate positive given a little Google searching, but not sure. Can anyone confirm? |
10-17-2016, 11:52 AM | #283 | |
Rep 2,942
Furthermore, Sennheiser and Grado are known for different things sonically: the former for accuracy and clarity, the latter for warmth and revealing details -- and only above a certain price point for both (unless you're talking about the Sennheiser PX100, which IMHO is the best pair of sub-$50 headphones you can buy.) Sorry that your request is confusing to those who know enough ...
10-17-2016, 11:53 AM | #284 | |
Rep 465
I don't know if you'd agree with me about the Sennheisers but I think the Etons are very much like this. What I don't remember was the treble performance of the Sennheisers. The Etons are not as bright as other speakers I've heard but they are nevertheless very good at the upper end and very easy to listen to in that regard. But I'm older now and I probably have lost some of my upper hearing so I wouldn't trust myself to make a judgment with respect to the upper end anyway. Last edited by selmeralto; 10-17-2016 at 03:19 PM.. |
10-17-2016, 12:07 PM | #285 |
Rep 120
Sel, I have the etons the mail. Sounds like I made the right choice. I feel that same away about the senns. Vocal clarity and sharpness. They sound great to my ears. Thank you gentlemen for your fast responses. Mike I had the px100 I loved them. It took the ultimate ears triple fi 10 to beat them. (they are also $300!)
10-17-2016, 03:58 PM | #286 | |
Rep 2,942
jase2addict : I hear you (pun partially intended). I'm on my third pair of PX100s as my go-to "use 'em anywhere" headphones ... but I own eight pair for different uses, including a set of Shure SE425s (second set of Shures; @$300 new ... the first in-ear Shures I had lasted 9 years and were $500 new), which are easily the most accurate pair I own. LOVE wired in-ears.
