2Addicts | BMW 2-Series forum Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics My Bavsound Ghost Subwoofer / Bimmertech Amp Review (WIP)
      07-22-2016, 07:54 AM   #45
RoarinRow
RoarinRow's Avatar
Drives: 2012 328i Glacier Silver
2012 BMW 328i  [0.00]
2014 BMW X1  [0.00]
Originally Posted by Zooks527 View Post
Depends on the settings of other switches.
1&2 on together drops overall amp gain down by 2dB.
3&4 on together drops the subwoofers down by 2dB.
Effectively, you've dropped the entire output of the amp down and then dropped the subs even more. Not sure that's really what you're looking for. Not sure why DIP 5 muted anything. It should have no effect of the remote isn't connected or if switch 6 is off.
Thank you for this info. I must be doing something else wrong because even when I had just 2 and 4 switched on their wasn't a dynamic sound compared to the OEM amp. That's why I was fiddling with switches.
      07-22-2016, 07:10 PM   #46
BentZero
BentZero's Avatar
Have you checked your dsp settings? Perhaps it got set to flat somehow?
Build thread
      07-22-2016, 09:55 PM   #47
RoarinRow
RoarinRow's Avatar
2014 BMW X1  [0.00]
Ok so I put the settings back to 2 and 4 on then used the 3.1 ADP software and tested 3 files from Bimmer-tech. Now The system is awake and this is what I expected when I first plugged it in. But so many dang adjustments in the tool. Guess I would need to try what other people have created as well for comparison. At first I was so disappointed.
I'll be ready when my Ghost subs come next week. Then I will have a complete system. At least for me.
      07-23-2016, 06:03 AM   #48
Zooks527
I started a thread for archiving tunes here: http://www.2addicts.com/forums/showthread.php?t=1232178
It never got traction, but there's a couple there. As mentioned in the thread, I modified mine by muting the center channel as well. I didn't post it, as I'm not sure channel muting is carried in the file, and I didn't want to confuse the issue.
      07-23-2016, 04:23 PM   #49
RoarinRow
RoarinRow's Avatar
2014 BMW X1  [0.00]
It never got traction, but there's a couple there. As mentioned in the thread, I modified mine by muting the center channel as well. I didn't to post it, as I'm not sure channel muting is carried in the file, and I didn't want to confuse the issue.
Very cool thank you. I'll throw the ones I have up on your post as well.
2012 328i Sedan - Glacier Silver - 18" Toyo Proxes 4 Plus Tires with Nürburgring Metal Grey Rims, H&R Sport Springs, VRSF Intercooler, JB+, aFe Air Filter, Magnaflow Exhaust, Carbon Fiber accents, SS Pedals, Bavsound System, BMW CCA member since 2015. First Bimmer - 2000 Z3 M. Second Bimmer - 2014 X1 sDrive28.
Search this Thread:
