06-15-2015, 04:17 PM | #23 | |
Rep 77
06-15-2015, 04:22 PM | #24 |
Rep 2,337
Your mom likes class D.
Seriously though, different applications, different needs. A class D amp for a ported sub is perfect. Who would bother with a trouble of a class A/B amplifier and then not use a sealed enclosure? Audiophile or not, spending $3000 on an amp that doesn't sound acoustically any different to your ear than a $500 amp is the real waste of money.
06-15-2015, 05:29 PM | #25 |
Rep 986
No need to apologize. I love Class D amps for low frequency. Typically the die hard subwoofer SPL guys don't care about sound-quality. Ported boxes are for getting the most out of your specific drivers, and giving a bump in output around the FS of the driver... D's are great for lows and great price points, stable to 1 ohm, and now even 0.5 ohm. Gives flexibility.
My perceived audio quality is subjective. Also isn't D > B > A ? |
06-16-2015, 03:38 PM | #26 |
Rep 2,942
I'm an audiophile. But I'm not a total snob. (Most of the time.)
I'm also a somewhat accomplished bass guitar player who knows gear both modern and vintage, and I've run everything from Class A Sunn and Ampeg tube heads to tiny Class D microamps on stage. Believe me: Class D can sound juuuust fine. Actually, it can sound daaaaamn good. What zipphreak says is true: many who claim they understand bass reproduction actually only care about how it affects them physically (SPL, how the bowels rattle and jiggle and quiver, etc.). Believe me: power is just one part of a pretty complex equation.
06-21-2015, 02:32 AM | #27 | |
Rep 7,047
The HK logic7 in my 335i has plenty of sub bass volume, but there isn't the same level of actual bass quality. There isn't very good bass note quality to match it's volume level. Part of that problem is the lack of good mid-bass drivers that have quality reproduction. It sounds like they tuned the HK system in the 3 series for pop and hip hop type music where they want volume and low bass extension with a disregard for actual reproduction. Use a quality piano only recording where the piano is being played from high to low and you can hear the big lack of even frequency reproduction. The HK system in my 335i has a multi band graphic eq, but fiddle all you want you can't make it much better than what is there. EQ is for fine tuning but not for correcting poor driver choice along with poor cross over selection. The HK system uses titanium dome tweeters, and I do not like those. Titanium domes do have very high frequency extension and can produce what the human ear can hear up to 20Khz. However, the highs they produce are harsh in quality and quickly lead to "hearing fatigue". You notice this by wanting to turn the volume done after a short while of listening. My favorite are silk dome tweeters. On top of this the HK system uses 2 x 8" subs under the seats. Those are used in the 3 series and 2 series, just as in the 1 series. Two 8.5" subs can sound good and give plenty of low end, however, the lack of quality of the sub drivers used in the HK system are a let down. They don't have the magnet strength needed to give tight and controlled low bass extension. They just can't do it because they are a cheap driver. I installed Earthquake shallow subs in my 135i and those were much better. The problem was that the stock amp then showed it's lack of quality. All the links in the chain matter. The weakest link will show over all weakness. Sounds like BMW isn't and hasn't upgraded the HK audio system for the 2 series. They'll just keep charging more for less in the 2 series compared to what you get in the 3 series for the same money. That's really BS and frankly dishonest imo. This car is targeted and marketed towards a younger buyer in the US. Well, to me that means get the audio correct. Last edited by RPM90; 06-21-2015 at 04:50 AM.. |
06-24-2015, 04:54 PM | #28 | |
Rep 2,942
1). The tastes of masses that either don't care, listen to a lot of talk radio/audiobooks or talk on the hands-free phone, or don't appreciate low-compression music (much less know what it is) in what is essentially an extremely bad listening room: the car interior. 2). Subpar speaker drivers that are "matched" to two flat-plane chip amps so as to not blow -- speakers OR amp -- if someone turns it up loud. (The three biggest signs of this: lack of low-mid articulation in the door drivers, that the subs are 2 ohm and the rest of the speakers are 4 ohm, and the omission of multi-frequency tone control). What we have is a very bare-bones audio system sonically in the 2-series. Either option -- Hi-Fi or HK -- is designed like this. It's quite sad, but not totally surprising in what is essentially BMW's entry-level car.
06-25-2015, 05:19 PM | #29 |
Rep 7,047
07-04-2015, 01:52 PM | #30 |
Rep 7,047
UPDATE:
I heard the base USA audio system in the M235i. WOW. If the audio engineer who designed and signed off on that POS in the 2 series were in the car with me I would have slapped him hard or maybe thrown him out of the car. The base audio system is so f'ing bad that I question my choice for choosing BMW. Simply horrid. It has no definition, no clarity, and don't try to turn it up past a normal conversation volume level as it will fall apart completely. I've heard better sounding boom boxes from Walmart. I also recently heard the B&O system in an Audi S3. VERY nice. It is better than the HK system in my F30 335i, and my HK. I have not had an opportunity to listen to the HK system in the 2 series. |
07-04-2015, 03:26 PM | #31 | |
Rep 757
07-06-2015, 12:32 PM | #32 | |
7485
Rep 12,307
I'll probably end up going this route with the M2. Not an audiophile by any means, but this is just the consensus from what I've read.
Current:
16 F82 M4 GTS, Black Sapphire/Black, DCT 08 E92 M3, Sparkling Graphite/Bamboo Beige, 6MT 07 E85 Z4M Roadster, Alpine White/Red, 6MT 99 E36 M3, Techno Violet/Dove Grey, 6MT |
07-06-2015, 12:42 PM | #33 |
Rep 2,337
Exactly. I have a high quality set of speakers I can take out of my M235i and put on my next BMW. Initial investment is about what I would pay for the HK option, but now I have a better system than HK and can continue enjoying it in the next car. Those who got the HK got a rather ho-hum system for a lot of money and will probably get another ho-hum system next time around - when BMW decides people will pay $950 for it
07-06-2015, 01:37 PM | #34 | |
Rep 2,942
If you want a decent-sounding system in a 2-series, get the base system and upgrade that. It's easier, relatively cost effective (can be done acceptably for under $1K), and you have some options.
07-07-2015, 09:42 PM | #35 | |
Rep 6,934
Drives: 2018 M2 AW DCT
07-08-2015, 11:07 AM | #36 |
7485
Rep 12,307
That's really good to know. I don't know much about these things, I'll admit, so I'm just going to follow what you guys do
Current:
07-08-2015, 12:25 PM | #37 |
Rep 228
Seriously? This isnt 1996. And if you are going to sit there and tell me you can tell what class an amp is, while driving 50+ mph in a 2 series, ALL ELSE BEING EQUAL, then you are quite the phenom.
I love my old A/B dont get me wrong. And while parked, they probably sound a little better. But they are also 8x's larger than my class d amps, make less than half the power, and could fry an egg after an hour of playing. Modern Class D is no slouch. And considering Andy W's winning systems used those flat chip amps, I would say those aint to bad either. |
07-08-2015, 12:29 PM | #38 | |
Rep 228
07-09-2015, 02:56 PM | #39 | |
Rep 2,942
It's jitter city inside the CD slot in my HU ... and I'm realistic enough to realize that I probably won't convince the dealer that my HU may be defective unless another issue comes up. They likely wouldn't know the difference between jitter and the jitterbug ...
07-13-2015, 11:20 AM | #40 |
Rep 33
If you lease, the HK system is definitely worth the $875 upgrade over the factory system - it is adding only $20-$25 per month to your payment, if that. No point in dropping $1k on a system unless you plan on moving it to your next vehicle.
That being said, the best execution of the HK system is by far, in the i3, no doubt due to the shape of the interior. It even blows the B&O system from the 5, 6, 7, X5, X6 system out of the water. In the 2-series, unfortunately, you get the least effective system, with no equalizer and fewer speakers. Hopefully, the M2 comes with HK standard, and a better setup. |
07-13-2015, 12:24 PM | #41 | |
Rep 228
07-15-2015, 09:00 AM | #42 |
Rep 33
07-15-2015, 07:35 PM | #43 |
Rep 77
For those of you interested in hi res audio.....do the research.
http://hiresaudiocentral.com/afterma...-for-your-car/ btw: class D amps do suck. |
07-16-2015, 03:13 PM | #44 | |
Rep 2,942
Hey, dude, go for it if you want. In the meantime, I'll hit a D through my 1,200-watt Genz-Benz CLASS D bass amp and be louder than you, anyway.
