07-27-2016, 09:44 AM | #23 | |
Rep 260
I have the same camera in mine but bought from ebay seller estore009. I've bought a few cameras from them over the years and they're legit. Camera came in about a week, which is pretty impressive for a package from China. I have it tapped into the same fuse as the radio using an add-a-fuse. |
07-31-2016, 06:33 PM | #24 |
Rep 1,452
I have a Garmin Nuvicam. 7 inch screen,speed limits and it's also a GPS with lifetime traffic and maps. I can use the BMW display for other things while I view the maps on my Garmin. Just plugged into the lighter though.
08-01-2016, 11:26 AM | #25 |
Rep 18
I have a 228i base and installed my A119 dash cam (not hardwired.) If I leave it plugged in when I lock the car, the cam turns off after 30seconds - a minute or so. When I come back to the car and unlock it, the power kicks on. I just want to confirm this is the case because I don't want the dashcam to trickle drain my battery.
Anybody know for sure? |
08-01-2016, 12:16 PM | #26 | |
Rep 8,364
08-01-2016, 12:34 PM | #27 | |
Rep 886
08-03-2016, 06:17 PM | #29 | |
Rep 765
Just installed the A119 myself and really like how small and out of line of sight it is. I just wish the manual explained the buttons and other option settings better.
08-03-2016, 08:54 PM | #30 | |
Rep 1,452
08-04-2016, 01:00 PM | #31 | |
Rep 18
08-04-2016, 06:42 PM | #32 |
Rep 765
Check under the coding section to learn. I found it very easy. Bought a USB-ODBII cable, had an extra windows laptop, and good to go. This thread is a good place to start:
http://www.2addicts.com/forums/showthread.php?t=997749 And Pikcachu is the man to talk to if you hit a stumbling block. You can't really screw it up once inside the system, since you can always just reset it.
08-04-2016, 08:55 PM | #33 | |
Rep 8,364
08-04-2016, 09:24 PM | #34 |
Rep 393
Blackvue DR650GW-2CH..
Pros: Incredible unit.. Beautiful, zoomable video, good interior audio, easy to install and discreet, built in wi-fi. Completely installed in less than an hour. Cons: A tad expensive but worth it.. I think I paid $290, runs a tiny bit hot. If on the fence, pull the trigger. I'm glad I did.. |
08-04-2016, 10:25 PM | #35 |
Rep 33
I went with the Advanced Eye. Expensive as hell but it's installed with all the wires hidden, gives me front and back video, and it manages the battery level with the car and will cut out if the level drops too low.
08-06-2016, 12:31 PM | #36 |
Rep 227
I have a waylens preordered from kickstarter. They are starting to ship now.
http://www.waylens.com |
08-06-2016, 07:09 PM | #37 | |
Rep 765
08-07-2016, 12:43 AM | #38 |
Rep 509
Drives: 2016 M235i RWD 6MT
I have the Spy Tech G1WH installed. Easily found on Amazon and if you really dislike it, you can return it. I didn't return it, I like it. I also would like to add that although it says 32GB max, I installed a 64GB and it works perfectly fine.
I know it's a bit bulky in a way compared to some of the smaller ones but it doesn't bother me.
2015 ES350 6AT - Traded In 2004 RX330 5AT - Sold 2004 Civic Coupe Si(EX) 5MT - Retired 1993 Civic Coupe Si(EX) 5MT - Retired |
08-07-2016, 12:50 AM | #39 | |
Rep 509
I'm curious of the price though.
08-09-2016, 02:49 PM | #40 | ||
Rep 227
So higher on the price side, but also quite a bit different than rea lot of the typical cheap Chinese dashcam options. The OBDII connection, onboard display and editing features in addition to the (supposedly) very solid video performance should make it worth the price if it delivers. Hoping to have mine in the next month or so.
Current
19' G05 X5 40i 03' e46 M3 Convert. Past09' e90 335d, 11' E70 X5d, 16' F22 M235xi |
08-10-2016, 12:54 AM | #41 |
Rep 509
$250 is a feasible price but dang $399 is ludicrous. I guess it doubles up as an action cam since they've compared it to the GoPro Hero4...not convinced it's an action cam though. The video quality I admit is very crisp and good on low light, but aside from security for the occupants and video recording, how often is it ever going to be accessed unless you constantly track your car and can use it as a recording piece for time?
08-10-2016, 11:03 AM | #42 | |
Rep 227
I would guess it will come down in price over time too. New startup and their first product.
Current
08-10-2016, 03:41 PM | #43 |
Rep 61
Just installed the Blackvue DR650S-2CH. Great cam, this is the newly released upgrade to the DR650DW-2CH. Very small front and rear cams, very stealthy.
Many issues with the "DW" have been resolved (per my dealer). Front and Rear camera (capacitor), power management for recording while parked, with cutoff at 12V. 128 GM micro SD. All that = $ 489 Install = $250 Pricey, but it's one of the best. Best to buy from a registered Blackvue dealer. I like these guys: http://www.thedashcamstore.com/ |
08-17-2016, 10:48 PM | #44 |
The Schwab
473
Rep 1,605
Drives: 2020 AW M340xi
Anyone use the Thinkware F770? It looks amazing but slightly pricey ($425) for front, rear, and hardwire kit.
