12-17-2015, 05:02 PM | #45 |
Rep 2
Thanks a lot for your Topic.
I have the same installed in my car: BMW “F30”335XD year: 2013 monitor screen 8”8. The same interface but I have on problem when the screen display the GPS mode the icons in the left are cut. I try to change the dips in each configuration is the same, I sent the interface for the provider they made an update on the firmware and after I have the same problem. Do you have an idea about this bugs and do you have the same bugs in your model for the 8”8 displays for F30 BMW? Regards |
01-09-2016, 08:48 AM | #46 |
Rep 204
Thank you very much to the original poster. I looked at your first video, looked at the price of the kit, and decided that since I just ordered my car yesterday, I may go back and add the rear view camera to my order. I thought the BMW price was outrageous and that I could get something for a couple of hundred bucks and slap it in in an hour or two. Now I know better.
02-05-2016, 02:45 PM | #48 |
BMW newbie
11
Rep 61
Thanks to OP
Im in the process of installing the front & rear cam with the mirroring kit into my 335i manual... So more steps than automatic. There were a lot of little steps that were skipped (not due to having a different series) but still helped a ton. They (bimmertech) need to work on an installation guide for those like me who really wants to DIY... For the amount of money poured into this, there should be a small booklet of instructions full of diagrams & pictures to guide the consumer. It's very doable but we will see if I can successfully finish this little project. |
02-06-2016, 10:00 AM | #49 | |
Rep 1,753
05-07-2016, 03:46 AM | #50 |
Rep 1,151
05-07-2016, 08:33 AM | #51 |
Rep 54
I'm debating on the MMI or oem integration myself. I was told the oem integration will need coding, which they give you remotely. Was there ever a group buy?
05-24-2016, 05:00 PM | #52 | |
Ne Plus Ultra
88
Rep 264
Drives: Portimao Blue 2022 M240iXdrive
07-04-2016, 07:45 AM | #53 |
Rep 5
I recently purchased the OEM integration kit. If you are not sure which one to get, just call Bimmer tech. I was debating between OEM integration and MMI. After talking to Bimmertech, I found out that I should go with OEM Int because I have Nav and there is almost no space for MMI (the OEM int module is a lot smaller). The kit showed up in a few days and seems to be of good quality and it works great and look like it was oem. I decided to DIY to save $400 bucks. If you want to go with the DIY route, get the tools and watch the bimmer tech video AND the one from the OP. I have it about 90% figure out and the rest is not that hard. Ran into a little problem with my work computer during coding because I can't get the firewall turned off. End up borrowing my friends lap top. As far as the support I get from Skype , it was great and friendly. I even get some free coding like DVDs in motion and tire temp and pressure coded during the coding session.
http://www.bimmer-tech.net/bmw-rear-view-cameras/ I am happy! |
