01-05-2015, 11:05 PM | #1 |
Rep 1,078
I finally hardwired my Blackvue dash cams after a lot of research and trial and error. Being my first dash cam install and the fact that I've never dealt with fuses before made this project somewhat challenging at first. But in the end, it wasn't all that bad at all. The setup includes a front and rear camera setup to record both when parked and when the car is on.
I originally went with the PowerMagic Pro but from watching YouTube videos, that product has issues with cars that have the stop/go technology. Although I never really use it, I decided to go with the Multi Safer anyways just in case. The Multi Safer is programmed to either turn off the camera when the voltage drops below 12.2v or when it's been in parking mode for a straight 24 hours, whichever comes first. The camera is also only triggered based on motion when in parking mode. I used 2 add a fuse circuits, one for ACC and 1 for constant power. You can see the Multi Safer mounted in the trunk next to the fusebox. Routing the wires in the car was particularly challenging because they give you way more cable than you need and hiding the excess wires was somewhat difficult. The connector from the Multi Safer to the cigarette lighter plug from the camera was also very loose, so I ended up mounting the Multi Safer to wedge the two pieces together. I would recommend duct taping the 2 together as they tend to come lose as you drive. The Multi Safer has a button and 2 leds. The leds can actually tell you your current battery voltage as well as the mode of the Multi Safer. The button allows you to choose between 2 modes - Always on mode or only on when the car is on. It's nice to have this option as you can turn off the always on mode if you are going to leave the car parked at home in a garage for a long period of time, for example. Overall, I am pretty happy with the setup and I feel more secure both while driving and while the car is off. Let me know if you have any questions. |
01-09-2015, 11:53 PM | #2 |
Rep 630
Drives: 2021 G80 M3
Any sample videos to share? Have you tested it all with the car parked? Been looking at this setup and interested in some real world feedback.
01-10-2015, 10:35 AM | #3 | |
Rep 1,078
https://www.youtube.com/watch?v=hJU6It9uETU Last edited by mikeyymonster; 01-10-2015 at 10:15 PM.. |
02-22-2015, 10:34 AM | #4 |
Rep 195
Drives: MY14 MG M235i 8-AT
did you have to take any trim apart to feed the 2 wires, or were you able to tuck everything in without needing to remove (loosen) trim or parts?
I have been waiting for a nice day to install mine but have pseudo ran the remote cable just to see what was in store... it seems there is plenty of room around the trim to stash the 2 cables but getting the power through the rear pass seat into the trunk, looks like I may need to remove a piece or 2 in order to snake them through? (the seat belt area part?) looks good, thanks for the pics. now I know where to tap into the fuse box! |
02-22-2015, 12:25 PM | #5 |
Rep 395
I just did this exact same install minus the multi safer. I used the Power Magic Pro and I am having problems with it already. I think I will buy a multi safer.
You don't need to take any trim apart. You just need a little tool to help you pry things once and awhile. |
02-22-2015, 12:26 PM | #6 | |
Rep 395
By the way, I have found that the BMW shuts all power off after a certain period of time, so it was necessary to hardwire the constant power directly to the battery rather than a fuse that gets shut off. The ACC can go to a fuse. |
02-22-2015, 12:44 PM | #7 |
Rep 1,078
If I don't drive my car for over 24 hrs then yes the car detects battery drainage and turns off all power. If you drive your car daily u shouldn't have a problem with either the power magic pro or multisafer. If I know I'm going to leave my car parked for an extended period of time in my garage I just simply unplug the power to my camera. No point in recording at home anyways.
02-22-2015, 10:11 PM | #8 | |
Rep 765
02-22-2015, 10:45 PM | #9 |
Rep 1,078
Just out of curiosity, when you wire to the battery directly, are you simply wrapping the wire around the positive terminal? Or are there cleaner alternatives like the add a fuse circuits used for fuses?
02-23-2015, 12:09 AM | #10 |
Rep 395
There is actually a perfect little area next to the battery terminal that has its own little nut. You take that nut off and use a 2 prong cable end on the bolt and then put the nut back on. Looks OEM
02-23-2015, 12:10 AM | #11 | |
Rep 395
02-23-2015, 12:19 AM | #12 | |
Rep 1,078
02-27-2015, 06:33 PM | #15 |
Rep 1,078
I separated the 2 wires so that it's not as bulky when hiding. The main unit is routed on the left side of the moulding to the back of the trunk (through the backseats) and the rear camera is connected to the main unit on the right side of the car. Routing the wires is probably the most annoying part of the install as you want to keep them hidden.
02-27-2015, 07:53 PM | #16 | |
Rep 44
02-28-2015, 02:16 AM | #17 | |
Rep 395
02-28-2015, 12:51 PM | #18 |
Rep 395
Hey Lazee 1 has your GPS been working correctly on your 650GW? I was watching some of the videos this past week using the Blackvue program on my mac and noticed that GPS cuts in and out. I read online that this is an issue with the blackvue after it overheats and then it requires replacement.
03-10-2015, 10:59 PM | #20 |
Rep 765
Does the review mirror cover it up from the driver's seat? It looks almost as if you would never see it as a driver (which is preferred for my tastes).
06-05-2015, 05:16 PM | #21 |
Rep 84
Do you need to use two same AMP fuse within the fuse tap or higher amp for the blackvue?
What amp fuse are the two taps that you used? Last edited by BBMMWW333; 06-05-2015 at 05:46 PM.. |
06-05-2015, 07:02 PM | #22 |
Rep 1,078
Both are 5 amp fuses. What are you trying to hook up?
