2Addicts | BMW 2-Series forum Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics No mid adjustment
      05-26-2022, 08:29 PM   #1
nazali
nazali's Avatar
Drives: 230 2020 vert F23
No mid adjustment
After living with the car for a while, and also having the HK,
I don't know why there is no MID-RANGE adjustment,
power and bass isn't everything, I have plenty of both
but depending on the source there is a muddiness which comes from not being able to inject more mid into music.
it's hit and miss increasing the top and too much bass, gives a thud instead of a nice crisp bass.
annoying especially on a 50k car you can't adjust that.
even if I upgrade the speakers what use if I don't have proper eq
on the 1 series, NO HK, I was able to effect better tone control
I'm almost certain I had a mid setting
      05-27-2022, 04:22 PM   #2
Kernel Kurtz
Kernel Kurtz's Avatar
345
Drives: 2020 M240i xDrive
Yeah not having an equalizer is pretty lame for their top sound option on the F22. Much cheaper cars at least have EQs on much worse stereos.
It is what it is. I have a high end system at home (no need for EQ there) so I just try and listen to the nice exhaust note more when I am driving.
nazali1295.00
      05-28-2022, 12:30 PM   #3
MarcoZandrini
Drives: 2018 M240i
BMW cheaped out on the F22/23 audio system. There are options, though:
- speakers: bavsound or integral or focal or Eton
- amp: integral or Audiotech-Fischer (MATCH 7UP BMW)
- sound deadening: various
nazali1295.00
      05-28-2022, 02:12 PM   #4
nazali
nazali's Avatar
txs for the replies, but just changing speakers amps etc, without a way of changing the Eq doesn't really change things, the speakers are still only going to be fed the same frequencies from the amp or head unit ? I mean the sensitivity and there respond frequency may be better ? but if a speaker gets (for arguments sake) 20khz, that's all it's going to put out. It can't put out 25/30 200. Unless your putting some form of signal processing from the HU, to the amp, or amp to spkrs ?
      05-28-2022, 02:14 PM   #5
nazali
nazali's Avatar
There was a "free" trick I read on here, about removing the center speaker on the dash
to help with sound staging ? does that help much ?
      05-29-2022, 08:59 AM   #6
MarcoZandrini
Drives: 2018 M240i
I installed an Audiotec-Fischer amp that's completely tunable via a laptop and the company's free software.
Amp: https://www.audiotec-fischer.de/en/m...ifiers/up-7bmw
Software: https://www.audiotec-fischer.de/en/tools/dsp-pc-tool-5/
nazali1295.00
      05-29-2022, 08:32 PM   #7
nazali
nazali's Avatar
The problem with that, is no easy quick method to tune. As between songs/tracks and even sources the sound envelope changes, you may want more less bass/mid /top.
I mean as an initial setup that sounds great, but unless you have some form of eq at your fingers that kinda still sounds like too much hard work.
Of course there are work arounds and not knocking anyone for trying.
Basically just amazed on a 50k car there is no mid control LOL
      05-30-2022, 11:25 AM   #8
aerobod
aerobod's Avatar
3609
I have an $80K car with no sound system, A/C, doors, roof, windows, power brakes, power steering or electronics other than instruments and ECU.
It really depends on the buyer market needs as a whole. I find the M240i too noisy to bother with anything other than a basic system, unless you turn the sound up a lot, but then hearing loss and not being able to hear emergency vehicle sirens become an issue.
nazali1295.00
      06-03-2022, 04:26 PM   #9
Climate Changer
Climate Changer's Avatar
2018 230i xdrive co ...  [0.00]
2019 x3  [0.00]
Bimmer Code. In expert mode. Change the audio file to F45. Check the coding form for details. And disconnect your center channel speaker.
Your Welcome
nazali1295.00
      06-04-2022, 01:01 PM   #10
nazali
nazali's Avatar
WAIT WHAT,
what does this voodoo do ?
give me back my mid adjustment ?
Your Welcome
      06-04-2022, 01:07 PM   #11
nazali
nazali's Avatar
ok thank you google
https://www.2addicts.com/forums/show....php?t=1723637
https://f87.bimmerpost.com/forums/sh...php?p=26576098
      06-04-2022, 01:08 PM   #12
nazali
nazali's Avatar
when I feel brave enough to use expert mode ! gulps
Your Welcome
      06-18-2022, 08:09 PM   #13
nazali
nazali's Avatar
Hey guy's I did what is considered a 1st stage upgrade (from 2addicts thread and a couple of youtube vids)
I removed the front dash speakers, on mine there is a mid and tweeter combo,
instant difference, not as muddy and also louder. Lot more clarity.
When I feel brave enough I try the F45 eq thing using bimmercode
      06-18-2022, 08:10 PM   #14
nazali
nazali's Avatar
txs did that, BIG difference, not done the coding though just removed the speaker
Your Welcome
Search this Thread:
