Double check for stage 1 supporting modifications + Need to check for super knock? |
05-01-2022, 02:39 PM | #1 |
Rep 30
Hey guys,
Planning on modifying my car for the first time and wanted to double check that I am doing everything right. I have a 2015 m235i with 27k miles on it. AFAIK coils/plugs have never been changed. I plan on running BM3 stage 1 93 octane, also going with VRSF Charge Pipe and VRSF high flow downpipe. Questions/concerns are: Is the high flow DP worth it for stage 1? I've decided the exhaust/spool/HP gains are worth - unless someone can talk me out of it. No need for FMIC - most of the stuff I read doesn't require this for stage 1, I live in Canada and will be on OEM tune for half the year so doubt it will be worth. Replace stock plugs or get one step colder? Some sites say I should one or the other, but most people here don't seem to do any for stage 1. Since I plan on reverting to stock tune in winter, would it cause a problem for colder plugs? EDIT: Thanks guys! I am getting everything installed tomorrow and super excited! Plan to do my first few runs BM3 Stage 1 93 octane, I plan on filling up with Esso 93 octane. I've seen some people talk about super knock events - is this something I should be concerned about? I plan on logging the first few runs, any specific parameters I should look out for or will BM3 give a warning if I get knocking? Last edited by wantam235i; 05-23-2022 at 11:48 PM.. |
05-01-2022, 10:58 PM | #2 |
Rep 338
You don't need a cat at all, go catless, save money and make more power. The tune will remove any check engine lights from it. You don't need to change the tune for the winter either, just don't drive crazy if it's super cold. And you should be ok with stock plugs for stage 1 although they're cheap if you wanted to do them anyway.
05-04-2022, 08:49 AM | #3 |
Rep 190,777
Although the intercooler is not mandatory, I recommend upgrading the stock one. It's pretty bad.
Since you live in Canada and are running stage 1 only, a 5" core will do.
wantam235i4.00 |
05-04-2022, 11:24 AM | #4 |
Rep 4,913
Here is everything you need.
Downpipe - https://mad-us.com/mad-n55-downpipe-...2-335-435-4-0/ Charge pipe - https://mad-us.com/mad-n55-charge-pi...-435-rwd-only/ 5 inch Hd intercooler https://mad-us.com/mad-bmw-5-stepped...55-1-2-3-4-m2/
wantam235i4.00 |
05-05-2022, 01:58 PM | #5 |
Rep 87
I am also in Canada (Ottawa) and I ran bm3 Stage 1 93 for a year with just the charge pipe upgrade - no problems whatsoever. I then went Stage 2 and added a high flow cat DP and a 5" intercooler. Stage 1 is a real blast and a bigger gain over stock than the Stage 2 is over Stage 1.
Chris |
wantam235i4.00 |
05-06-2022, 09:11 AM | #6 | |
Rep 190,777
wantam235i4.00 |
05-06-2022, 09:30 AM | #7 |
Rep 736
Drives: Lexus RC F
I LOVED bm3 stg1 93, my only supporting mods were CP and CSF IC, made such a huge difference and when you back it up with xhp stg 2 trans flash (zf8), it was perfect.
Estoril Blue E36M3
wantam235i4.00 |
05-13-2022, 08:21 AM | #8 |
Rep 190,777
wantam235i4.00 |
05-20-2022, 03:42 PM | #9 | |
I like biscuits
164
Rep 250
I just did BM3 Stage 1 literally yesterday. My mods are Straight pipe exhaust, stock DP, intake and charge pipe. Definitely a night and day difference with the torque output. That 25% hp & tq claim most be accurate. The turbo spool and sound is just as intoxicating as the power increase. I plan on doing catless dp, fmic and zhp trans tune next! |
wantam235i4.00 |
05-23-2022, 11:46 PM | #10 |
Rep 30
Plan to do my first few runs BM3 Stage 1 93 octane, I plan on filling up with Esso 93 octane. I've seen some people talk about super knock events - is this something I should be concerned about? I plan on logging the first few runs, any specific parameters I should look out for or will BM3 give a warning if I get knocking? |
05-24-2022, 08:42 AM | #11 | |
Rep 190,777
wantam235i4.00 |
05-24-2022, 11:34 PM | #12 | |
Rep 30
I emailed protuningfreaks as well and they said I can run it on max safely, not sure how they can make that claim since the downpipe I intended to use is still catted. |
05-25-2022, 12:21 AM | #13 | |
Rep 190,777
My answer now is yes you are safe to run max burble on any downpipe
wantam235i4.00 |
