2Addicts | BMW 2-Series forum Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics Technic ASD install - 2021 M240 - additional info
      04-23-2022, 11:25 AM   #1
VAcurler
Drives: 21 F23 M240i MT + 09 e90 328i
Zooks527 wrote up an excellent installation guide called
Installing TechnicPnP Active Sound removal harness at
https://www.2addicts.com/forums/show....php?t=1202389
Having done this yesterday on my 2021 M240i Convertible I noticed a few things that took some extra time that I hadn't seen before so I decided to take a few pictures for those with a similar setup.
1. For those that have a rear seat fold down (like I did), it is two T-20 screws holding that in place. That wire will just hang down when you remove the panel. I thought I could remove the trim panel with it attached but you cannot.
      04-23-2022, 11:27 AM   #2
VAcurler
2. The quick disconnect shown in the prior instructions for the power port in the trunk was different so I disconnected it from the back. Attached are the two pictures.
      04-23-2022, 11:31 AM   #3
VAcurler
3. As mentioned on another post in that thread (that I did find) - on the current ASD units with the M240i you do NOT need to swap out connectors: "The cable comes almost ready to install, but it is necessary to swap the locking connector on the cable with the one in the car. It's a trivial piece of work, and I assume it's because the BMW OEM style lock is not available. "
I don't know if the cable changed or the connector changed but mine was absolutely plug and play.
Overall it took about 90 minutes to do the whole thing. If I was doing it again, I bet it would be 30 minutes. If anyone's in Denver wanting to do this I'd be happy to help.
