04-10-2022, 04:50 PM | #2 |
Rep 107
Look into the 550i/335is clutch. Seems many 2k series guys are doing this upgrade as it holds more torque than our OEM one does.
2016 M235i RWD 6MT, Full E85 Custom Tune via BM3, Stock Turbo, DS2 hpfp, stock lpfp, VRSF bolt ons, CTS Turbo Inlet
04-11-2022, 06:45 AM | #3 |
Rep 17
Is it a direct fit or Do I need to get other things for the clutch to work? Do you Maybe know the specific part number?
04-11-2022, 11:07 AM | #4 |
Rep 238
Drives: '17 M240i 6MT
04-11-2022, 11:19 AM | #5 | |
Rep 17
04-11-2022, 01:56 PM | #6 |
Rep 4,892
What mods do you have? The stock clutch isn't horrible....
04-11-2022, 01:58 PM | #7 |
Rep 643
M235i rwd 6mt
04-11-2022, 05:59 PM | #9 |
Rep 4,892
Then I would definitely go with a factory clutch. Most aftermarket clutches are not as easy to drive with a harder clutch pedal and can be more bitey. A factory clutch works very well.
04-11-2022, 06:02 PM | #10 |
Rep 17
Yeah but I am going stage 1 soon and stage 2+ next year so will it hold? The 550i/335is clutch is priced the same as the m235 clutch. My only worry is that the 335is clutch will not be a direct fit.
04-11-2022, 06:50 PM | #11 |
Rep 4,892
Yes it will. If you slip clutch or don't shift well then it may prematurely wear.
04-12-2022, 09:44 AM | #12 | |
Rep 643
direct swap. clutch feels factory. parts list from fcp euro: BMW Clutch Kit SKU: LUK-6243584000 BMW Clutch Release Bearing With Release Fork SKU: BMW-21517564027 BMW Clutch Fork Pivot SKU: BMW-21511223328 BMW Crankshaft Seal (just in case you find a leak) SKU: CTO-20036307B BMW Clutch Slave Cylinder (optional: this unit deletes the CDV) SKU: FTE-KN2207642 BMW Pressure Plate Bolt (qty 6) SKU: BMW-21207548052
M235i rwd 6mt
Wheelwright462.50 |
04-12-2022, 12:01 PM | #13 | ||
Rep 17
04-12-2022, 02:14 PM | #14 |
Rep 643
every single of those items i listed is sold separately at FCP euro. i notice you are in sweden, so i don't know if they ship there, however, you can use their website to look up the parts i listed and you can order from wherever is suitable for you. you can buy genuine bmw parts too if you go to the dealership.
M235i rwd 6mt
04-12-2022, 02:18 PM | #15 | |
Rep 17
